Question about Ultrex 259-218 Deep Fryer
Rust in bottom of 10/18 stainless steel pot
I have a set. The 10/18 stainless steel Ultrex pot is my problem. I boiled water for a large pot of tea and it tasted horrible. I tried 2 more times with the same result. Then I just boiled the water and it tasted worse than when I poured it in. After that, I did not use the pot. Then I needed to have a humidifier and used the pot to boil on the stove. Now there is rust on the side and bottom. What gives here? Isn't the coating like Teflon? What now?
  • Anonymous Apr 23, 2009
    I have a 12in frypan which has rust in the bottom also
  • 145 Answers
Use DeBruce Polish to pacify the steel, we get DeBruce Polish at We especially like it on Ceramic cook tops, refrigerators, stainless steel grills that rust- DeBruce removes it all. Debruce is ECO-FRIENDLY we love it, having replaced 6 products under our sinks DeBruce paid for itself.
Posted on Jul 27, 2009
Brand new! Cleaned it out with vinegar initially, poured in and turned it on. Still waiting, nothing is coming out at all. What's the problem?
LOL add another pot of water it has a storage tank of 1 pot might take several pots to get all the vinegar out .
Dec 22, 2015 | Bunn O-MATIC NHS 10-Cup Professional Home...
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    How do you use loose tea to make tea in a pot?
    You can use steel pot to make a Tea, do you know Loose tea is very simple to make.
    If you will use steel pot that is easy to hold and keep.
    Feb 27, 2013 | Home
    Bunn automatic coffeemaker leaks water after making a pot
    Tank and tank components should be delimed regularly
    depending on local water conditions. Excessive mineral build-up
    on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
    Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
    The internal base and tea leaf basket are tarnished from the tea. How can I clean them?
    "The best tea pots are never scoured clean". Ask any retired tea drinker.The same with tea strainers. It improves the tea flavour to have a clean but not scoured out strainer. Have I saved you a job?
    If you still want to and if the items are stainless steel, a scouring pad and washing up water will do it.
    Mar 10, 2011 | Microwave Ovens
    How to make marmalade
    Prep Time:45 minInactive Prep Time:24 hr 0 minCook Time:1 hr 0 min Level:Intermediate Serves:10 (8-ounce) jars Ingredients
    • 1 3/4 pounds oranges, 4 to 5 medium
    • 1 lemon, zest finely grated and juiced
    • 6 cups water
    • 3 pounds plus 12 ounces sugar
    • Special Equipment: 10 (8-ounce) canning jars with rings and lids, funnel, tongs, ladle, and 12-quart pot
    Directions Wash the oranges and lemon thoroughly. Cut the oranges into 1/8-inch slices using a mandolin, removing the seeds as you go. Stack the orange slices and cut them into quarters. Place the oranges into an 8-quart stainless steel pot. Add the lemon zest and juice and the water to the pot, set over high heat and bring to a boil, approximately 10 minutes. Once boiling, reduce the heat to maintain a rapid simmer and cook, stirring frequently, for 40 minutes or until the fruit is very soft.
    While the fruit is cooking, fill a large pot (at least 12-quart) 3/4 full with water, set over high heat and bring to a boil. Place 10 (8-ounce) jars and rings, canning funnel, ladle, and tongs into the boiling water and make sure the water covers the jars by at least an inch. Boil for 10 minutes. Turn off the heat, add the lids and leave everything in the pot until the marmalade is ready.
    Meanwhile, place a small plate in the freezer. Increase the heat under the orange mixture to return to full boil. Add the sugar and stir the mixture continually, until it reaches 222 to 223 degrees F on a deep-fry or candy thermometer, and darkens in color, approximately 15 to 20 minutes. You may need to adjust the heat in order to prevent boil over. Test the readiness of the marmalade by placing a teaspoon of the mixture onto the chilled plate and allowing it to sit for 30 seconds. Tilt the plate. The mixture should be a soft gel that moves slightly. If mixture is thin and runs easily, it is not ready.
    Remove jars from the water and drain on a clean towel. Place a canning funnel onto the top of 1 of the jars and ladle in the marmalade just to below the bottom of the threads of the jar. Repeat until all of the mixture has been used. The amount of marmalade may vary by 1 to 2 jars. Wipe the rims and threads of the jars with a moist paper towel and top each with a lid.
    Place a ring on each jar and tighten.
    Return the jars to the pot with boiling water, being certain that they don't touch the bottom of the pot or each other. (If you don't have a jar rack, try a round cake rack, or metal mesh basket. Even a folded kitchen towel on the pot bottom will do in a pinch.) Add additional water if necessary to cover the jars by at least an inch. Boil for 10 minutes. Using canning tongs, carefully remove the jars from the water, place in a cool dry place and allow to sit at room temperature for at least 24 hours before opening. Once open, store in the refrigerator. Unopened marmalade will last for up to 6 months.
    Sep 25, 2010 | i-mate JAM Pocket PC
    Strong metal taste, how do I get rid of it. Coffee tastes terrible with very strong metal taste. I have boiled kettle about 8 times, but am unable to get rid of bad taste.
    Professional chefs face this problem many times over with their stainless steel wares. Fill the coffee pot with water. Add a tbs of bleach. Let set for 2 hours. See if that helps. If it doesn't, please let me know.
    Oct 20, 2009 | Breville SK500XL Stainless Steel Cordless...
    West Bend Lifetime Stove Top Coffee Maker This is a nice heavy stainless steel coffee maker, probably from the 50s or 60s. It has four parts; a carafe that sits on the stove, a piece that fits on that with...
    Not to sound like a knw it all, but we have a pot just like this. You have to boil the water in a seperate kettle and pour it in the pot. This is a drip pot, not a perculator. It will make the best coffe you've ever had.
    Jun 20, 2009 | Coffee Makers & Espresso Machines
    Burned pot
    a ceramic or clay pot is the only solution.steel is hopeless for casseroles
    same as frying eggs in a steel frypan without the teflon coating
    only true stainless steel is advisable
    May 15, 2008 | Rival 38501 Smart Pot 5-Quart
    Ultrex 259-218 Deep Fryer Logo
    232 people viewed this question
    Top Ultrex Kitchen Appliances - Others Experts
    Ruth summersides
    Tom Chichester
    Are you an Ultrex Kitchen Appliances - Other Expert? Answer questions, earn points and help others
