Question about E-Machines 17" Widescreen Flat Panel LCD Monitor
New 17" monitor won't display proper proportions - short & wide
I have tried everything with my properties and settings, and still have no driver than that for "standard monitor types". How do I get a driver installed for a wide lcd
I have an intel mobo D865GVHZ with integrated graphics. Do I have to install a whole new card?
    Sergeant:
    Champion:
  • 259 Answers
Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Posted on Jan 23, 2009
3 Suggested Answers
preachw996
  • 1179 Answers
SOURCE: new 17" monitor, display is wide and short, not proper proportion
The monitor should have came with an installation or drivers cd. Use this disc to install the monitor specific drivers for your operating system. If you do not have the cd then you should be able to download them from the support section of your monitor manufacturers website. Hope this helps & please remember to rate my answer. Thanks.
SOURCE: I have an intel D865GVHZ
I ran a scan that I downloaded free, then read results that showed driver that I needed, then I googled it, downloaded it free and solved the problem.
Posted on Jan 24, 2009
Borders on external monitor after Dell Latitude D630 wakes from sleep
Thomas Motley,
Your monitor is displaying like it is because the graphics card refresh rate has changed. Check that the display driver is correct for your graphics card and that you are not using the generic windows driver. If the driver is correct then look in desktop properties, settings, advanced, monitor and check that the refresh rate is correct for you monitor.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 27, 2013 | Dell LATITUDE Computers & Internet
Tip
How to change your Windows XP display settings 1. Right click on your desktop...
1. Right click on your desktop and select Properties
2. Click on the Settings tab
3. In the Screen Resolution section you can adjust the resolution to what your video card and monitor can support.
Note with wide screen monitors you will be able to select non wide screen resolutions so you may need to adjust the settings to get the best resolution for your monitor. Also it is recommended that you install any drivers for your monitor so that the video card can communicate to the monitor properly for the best display settings.
on Aug 15, 2010 | Computers & Internet
Tip
Trying to connect computer to LCD TV and get no signal?
Hi.
If you are trying to connect computer to LCD TV and get no signal, as a first thing do the following:
Double check cable and connection. If possible test different connections. Try using VGA, DVI or AV, depending on availability on computer and TV.
Ensure that Video drivers on computer are properly installed, and that the video adapter is working properly.
If you are using a laptop, ensure that you do not need to use a function button to enable the external display, this is pretty common on laptops.
If you are using a desktop, go to display properties, find the windows where you get the picture of two monitors, and ensure that both monitors are enabled.
On Vista try also using the 'Identify Monitor' button on Top. It is located on same properties panel as the two monitor, the main Display Property windows. From the same window you can also modify display resolution, as explained later.
If still no luck, then it may be a problem of synchronization between TV and computer, in that case try the following.
  1. Turn off TV.
  2. Disconnect TV power cord.
  3. Restart computer.
  4. With Computer already on, plug back and restart TV.
....If that does not work.
On computer, go to display properties.
First try changing computer resolution. The TV max resolution may not be available on computer. In that case try lowering down to the smallest 16:9 resolution available on computer graphic settings (usually LCD TVs are 16:9), and if that does not work, set resolution to 800x600, just to test (picture proportion will be distorted, or you get squared box on a 16:9 TV).
If that does not work, open Display Properties. In Display Properties access Advanced, and then Monitor settings (XP). On Vista choose Personalize in control panel, then Display Settings, and go straight to Monitor Settings, in there again go to Advanced.
Under the advanced monitor settings you will find a tab called monitor, in there you find the monitor frequency. Try setting this to 50Hz, if that does not work try 100 HZ, that is the output frequency of your TV. If you get unsupported frequency, revert value to normal.
on Jan 17, 2010 | Televison & Video
Settings brightness
Hi which monitor are you using? Connect a different monitor to same system to see if that monitor works correctly with that CPU with same settings or connect your monitor with another CPU which is working properly with different monitor to pinpoint exact problem first. Any monitor if gets old will have such problem. If monitor is okay then you can check if display driver is present or not by going to See how many output connections your monitor has if it has multiple input connections like display port, HDMI, DVI, etc, you can try connecting to different ports if your CPU supports to see which connection gives what type of display.
https://youtu.be/lOT4zLqMOWQ
This video has partial information about display settings. You can right click on desktop and select properties and make it to default settings.
Dec 19, 2017 | Samsung SyncMaster P2250 22 inch LCD...
Acer wide screen monitor 20'' font and images all
Right click on the desktop in a clear area and scroll down to either resolution or properties. From this you can experiment with resolution settings to see which setting best fits your display. After each setting change the computer will ask you if you want to accept the changes, it will give you 15 seconds for each change.
Jun 26, 2010 | Acer AL2016W 20" LCD Monitor
New 17" monitor, display is wide and short, not proper proportion
Jan 23, 2009 | E-Machines 17" Widescreen Flat Panel LCD...
Monitor displaying everything horizontally
Some monitors don't give orientation feedback to the video card to auto change the orientation when you move from a horizontal screen to vertical. what you need to do is get to display properties and advanced settings (right click desktop > properties > settings > advanced > video card settings > orientation) - you should find an option to change the orientation of the display - correct it accordingly. if the settings are not being saved after you restart, you need a video driver update - find it on your manufacturers website.
Jan 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Screen resolution
hi, try playing with the aspect ratio .. let me know
Dec 11, 2007 | Acer AL1916W 19" LCD Monitor
Monitor installtion
Hi Robin,
Hope this instruction well do solve like I met some problem like this. Try to reset the monitors setting manually in OSD (on screen display) mode. Look for frequency settings start at lower and have test it all. Respectively try to configure the video card frequency settings at Operating System GUID (Graphics user interface display) video card setting properties. Start from lower frequency and notice the each changes. When perfectly proportionate select Apply settings.
Best regards,
Rosener Guyano
Nov 13, 2007 | ASUS VW192S Monitor
E-Machines 17" Widescreen Flat Panel LCD Monitor Logo
486 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
