Question about Mitsubishi WD-Y57 57" Projection HDTV
Screen is not as bright
Looks like the screen is getting darker now that I notice, also looks like screen is kinda blicking some real light amount. like dark to light. Also for the 1st time it acted as if it did not want to come on? thanks for your help. SB party watching the steelers will not look goot. Hope I can fix in time.
    Scholar:
  • 140 Answers
Time for a replacement bulb.
If you feel ok replacing the the bulb yourself, they are available on the internet at a good cost.
If you don't, bring it into a service center near you. They normaly charge around $100-$200 to replace the bulb.
Posted on Jan 23, 2009
Screen to light and it all the way up
There is no app to make a screen brighter. Try going to a darker place when you use it and clean the screen. There are fingerprints on smartphones all the time and it looks bad.
Dec 19, 2013 | HP iPAQ H1910 Pocket PC
How can I make my screen darker?
Change the brightness in power settings
Jan 31, 2012 | Gateway Computers & Internet
Screen is too dark, barely can see the print. Is there an adjustment to use? was working fine a few days ago, then, has been getting darker.
Most computers have a key combination to increase brightness. This is usually Fn+UP for brighter on Fn+DOWN for darker. If this is not the correct key combo, look for keys that have symbols looking like the sun or a light, those keys combined with Fn will change the screen brightness. This can also be changed in Windows, if that is the OS you are using. Go to Start->Control Panel->Power Options and an opiton for screen brightness will be there. Also, right clicking the battery/power cord icon in the system tray can get you to the power options.
May 08, 2011 | Acer Aspire 5630-6288 Notebook
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Darker screen after replacing a samsung dlp lamp
DID YOU USE THE FOLLOWING LAMP
BP96-00826A (PHILIPS WRITTEN ON THE LAMP)? ALSO PLEASE CHECK THAT THE LAMP IS COMPLETELY SEATED OR IT WILL RESULT IN BRIGHTNESS ISSUES. THERE WAS ONE THAT I REPLACED THE LAMP IN AND I NOTICED THAT THE DIAL OPENING ON THE LAMP HOUSING WAS A BIT SMALL AND WOULD NOT ALLOW THE COMPLETE SEATING OF THE LAMP AND I HAD A DARK PICTURE AS A RESULT. I USED MY CORDLESS DRILL WITH THE PHILIPS HEAD STILL ATTACHED AND REAMED THE HOLE LARGER AND IT SOLVED THE PROBLEM.
HOPE THIS HELPS.
Jul 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
JOTVGUY
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
When tv warms up i get red dots in darker areas of screen
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to fix the problem.
Dec 29, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Mitsubishi WD-Y57 57" Projection HDTV Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
