Should gas pak fan run on med hi during heating
Tappan gas pack 4 ton installed 2002. One evening the house got cold and had to call a repairman. He simply sucked on the hose to the diaphram and everything started up. He switched the fan speed to med high saying that it should be operating at a higher speed. All is going well now. What type of filter should I use. Some say that don't use pleated filters because of air restrictions. Your suggestion.
    Novelist:
  • 88 Answers
Thanks for your question,
As far as what speed to run your unit, the speed should be around med, now as far as what type of filter for your system, a pleated style filter will keep the dust level down alot better than media or horse hair, these two do work but let alot of dust through, yes pleated will cause a little more air restriction, but not to the point of causing your unit to run badly, but here is the trick, you must change your filter monthly, no exceptions, to maintain the best efficancy, to lower your power bills, a clean filter is the best preventitive measure you can do for your system, now there are washable style filters on the market, they work great, all you have to do is take it out and wash it off, shake it out, and put it back in place, it costs a little more but the overall savings is worth the cost, I hope this helps to clairify your question about filters, please rate this for us , and thank you again for your question,
mr.grzz
Posted on Jan 23, 2009
Can the "heat" pack also be put in the freezer for a "cold" pack?
No the heat package is a chemical reaction caused by movement. It will not react to or hold cold temp.
Hope this helps Mike
Jun 14, 2015 | Duro-Med Industries Inc Therabeads Moist...
4 ton Amana -heat comes on sporadic in spring and fall (Every season change) Heat worked through 20 degree weather. Thermostat at 74. Today is 100% humidity and 52 degrees outside and heat won't work. By...
Assuming this is a heat pump I'm guessing you have a bad temp sensor. Your outdoor fan is likely controlled by a temp sensor so it only runs as needed during heating. Fan not coming on and compressor still needs cooled therefore compressor protection kicking in?????
Aug 12, 2017 | Amana Heating & Cooling
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
Is a model py1pnb036090abaa Payne gas pack large enoug
3 ton cooling capacity 90,000 btu heat capacity. In Vermont it would be enough if the home was a 4 or 5 star home. Remember it is only 80% efficient so you will only net 72,000 btu output.
Mar 09, 2010 | Heating & Cooling
Wont heat a 1,500 sqft one story home..air is cold by time gets to far end of home..gas pack 3 years old
One thing you can do is slow the blower down, this
will give you greater temperature rise and heat evenly.
The length of the home is what is needed.
Its possible that you need to have dampers installed in your ductwork or you need a booster fan installed
on the ductwork that feeds that side of the house.
My guess is that you need 80,000 btu heat output
to come close to heat the house. Since ductwork is
sized for cooling you would need 36,000 Btu Cooling
output. More information is needed
Feb 14, 2010 | Ruud UAMB Air Conditioner
My 2 ton ac with air won't run even the fan on
Hi; Does Your air handler have a small fuse on the circuit board. CHECK IT. What kind of heat do You have / heatpump/gas/total electric/. Need more info...alpharome416
Jan 22, 2010 | Heating & Cooling
How far from the house should the outside unit be located?
If your outdoor fan is a vertical discharge in other words if the fan blows the air up from the top of the unit then one foot from house is fine, but if it is horizontal discharge or blows it out the side then the airflow needs to be directed away from the house or the unit needs to be moved away from the house far enough that it doesn’t restrict the airflow.
For the blower running on high speed a 4 ton unit is usually 1600 cfm so on low cfm it may seem like high speed. There should be some speed taps on the indoor pc board and if you look in your installation guide it should tell you what taps you need to get the lower airflow if its not correct.
For the luke warm air in the 2 ton mode, the coil is a still 4 tons but the compressor now is only pumping 2 tons of refrigerant so the discharge temperature and head pressure will be much lower and that is what determines how much heat you get, so you will get less heat. The 2 ton mode is for times when you only need a little heat or cool, when you need more then you will get the 2nd stage which is the full 4 tons of heat.
Apr 21, 2009 | Heating & Cooling
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
Fan louder than normal
Sounds like whoever did the txv, changed the fan speed. Yes, the fan speed is adjustable. Some HVAC units can have up to 4 speeds on the motor. Low, Med Low, Med Hi, and Hi. this is so the same unit can be used for several different cooling coils and tonage. The faster the speed in the cooling mode, the less cool the air will be.
Sep 29, 2017 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
