* My dishwasher appears to fill up with water ok. * Once full it doesn't spray the water over the plates etc. * The timer appears to run as there is a humming sound. * After 10-15 mins it appears the water is pumped out and new water is pumped in. * Still the water is not being sprayed around. * Hence at the end when I open the door I have plates that have not been cleaned at all but it is quite hot inside the machine (looks like the water gets heated but it is not being pumped around to spray on the dirty items).
It sounds like your dishwasher is doing everything normal EXCEPT washing. The unit fills properly, the timer advances properly, the unit drains and goes through a rinse cycle, plus the water is heating. I would check your main wash pump for obstructions that may be clogging it, or if it is not running at all, you need to check the interconnecting wiring and/or something in the wash pump circuit that would prevent it from running. There should be a wiring diagram/tech sheet located behind the lower kick panel under the door. I hope this helps some. Good luck and let me know what you find.
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies LI 640 S
Ariston Technologies LI 640 S NA Dishwasher - Stainless...
have a ll 64 s na Ariston dishwasher Whan I ren the wash cycle it stops after the first wash, it...
(More)
have a ll 64 s na Ariston dishwasher Whan I ren the wash cycle it stops after the first wash, it drains and then stops. When finished the Crystal Care light flashes??? can you help
It appears that my Ariston Li640s is not draining or possibly not rinsing my dishes. I get an error...
(More)
It appears that my Ariston Li640s is not draining or possibly not rinsing my dishes. I get an error code of the forth LED blinking(eco wash).
my ariston dishwasher doesnt rinse all of sudden. I washes and then it lights the rinse light a...
(More)
my ariston dishwasher doesnt rinse all of sudden. I washes and then it lights the rinse light a little bit and then changes to dry without rinsing. Any ideas, thanks
Few days ago, when I started the dishwasher, light for programs was not flashing as usual. I thought...
(More)
Few days ago, when I started the dishwasher, light for programs was not flashing as usual. I thought that it is not important and choose program for washing. After finishing, the ECO program was flashing more frequently then usual, furthermore I have not choose that program for washing! Also, I have noticed that cap with detergent was closed and that dishes are not clean. I have tried several things. I have called official service department for Ariston, but technicians have been busy and not available for me. Then, I have tried to figure out what is wrong and try all programs for washing and only sink (3) was OK and have not show any error, but other programs have not finish there job! It stops after about half an hour, cap with detergent is closed and heater has not been started (water is cold). I wonder if you have faced with these kind of problem and if you could suggest and proposed the solution. Thank you.
