Question about Bosch Microwave Ovens
Bosch model HMV9305 touch pad not working
The key pad does not work on the power setting. We have to hit the power setting numerous time in just the right spot and then it will finally register
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove your circuit board from the old frame and install it in the new frame.
Posted on Jan 03, 2009
SOURCE: microwave
Prototech@usa.com has links all over the internet advertising a simple fix for microwave displays. I ordered one and they never sent it. Had to file a claim with Paypal. No communication until I threatened them, then they said it's on its way. I waited another week and it sitll didn't come. After six weeks of trying to get my money back, I finally got a refund. Now I have to start all over. Any suggestions for replacing a display BESIDES this sham operation?
Posted on Jul 07, 2009
rhozel2010
  • 269 Answers
SOURCE: Oven runs, display works, interior light works,
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for blown fuse.
Posted on Sep 12, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: touchpad doesn't work on ge model #jvm1540sn1ss
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number WB56X10826 from the Pros here for $114.62 plus shipping (that compares to $166.50 from GE!).
You can also find helpful exploded view diagrams at that link.
Then disconnect your keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Posted on May 28, 2010
Testimonial: "excellent information, and timely too...couldn't be any better, if I had a tech come to the house...thank you"
  • 8909 Answers
SOURCE: I have a Bosch Microwave,
If one of the door interlock switches is not switching properly, that can cause the turntable/light to come on eventhough the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Posted on Dec 30, 2010
No power. fuse looks ok...
Hello, you need to take int microwave in to have repaired, you can get severly shocked if you touched the wrong thing inside the microwave.
Dec 03, 2015 | Bosch HMV9305 Microwave Oven
How do I replace the touchpad on a Bosch microwave?
Most microwave manufactures do not sell parts to the public because if you open up a microwave oven and don't get it all back together exactly right, you could receive microwave burns or be blinded when you run it. Best to just take it to the recycling place and get a new one. Seriously, these things are extremely dangerous if you don't know what you are doing.
Mar 23, 2014 | Bosch HMV9305 Microwave Oven
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Feb 26, 2018 | Microwave Ovens
Bosch HMV9305
The Inside of the door has a plastic trim peice that can pop out with a screwdriver
DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Hmv9305/01 microwave @ 13months old the magnetron blew, authorized bosch repairman, replaced using bosch magnetron. warranty for 90 days jan of 2011 same problem, why does this happen? should i ditch...
With all due respect, what are you doing to it?
If you use it with nothing in the cavity, that will kill the magnetron otherwise it will last for years and years.
Very unusual and Bosch is a well respected name.
If there is a probem with the oven, Bosch will replace it so take it up with Bosch.
Apr 01, 2011 | Bosch HMV9305 Microwave Oven
Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Doesn't work
Sounds like your magnetron has failed and was going bad for some time.
I would contact Bosch to find their nearest authorized servicer.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Nov 28, 2008 | Bosch HMV9305 Microwave Oven
The microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 30, 2008 | Bosch HMV9305 Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
