Question about Dell (9228C) 200-Watt Power Supply
With destop wont turn on
I just remove the DVD drive of my Dell destop and clean it up. but when replace it back... my computer wont turn on...
Are there any tips that these branded computer could have?
  • Roberta Smith
    Roberta Smith May 11, 2010
    Recheck that everything is hooked up properly
    Robert
    Problem Solver:
  • 14 Answers
Robert was right make sure your computer is unplug from the power strip. now check the power supply cable to the mother board, then check the power cable to the harddrive, and then the DVD.once you put the power cable back into the computer you should get the power supply fan should come on, and the cpu fan should come on.
Next once you hit the on/off switch and green light should come on.
Posted on Jan 23, 2009
Instal DVD Rwriter hardware
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
In a computer, the components with moving parts are the most likely to fail.
If your Dell desktop is more than 2-3 years old, your DVD drive may be reaching the point where it is no longer performing correctly and must be replaced.
Replace the DVD drive in your Dell Desktop to return the computer to normal operation, so you can resume watching movies and burning discs
Turn your computer off completely, and unplug all of the cables from the back.
You may wish to label some of the cables with tape so you will not forget where they go when you put everything back together.
Move the computer to a sturdy work surface, and touch a grounded metal object to release any built-up static electricity.
Open the computer case by pulling the latch on the side of the unit if you have an XPS, or removing the thumb screws in the back if you have an Inspiron.
If you have a different type of Dell desktop or a very old model, you may need to consult the instruction manual for instructions on how to open the case.
Remove both cables from the back of the existing DVD drive.
Leave the data cable connected to the motherboard, and set both cables aside where you will be able to reach them easily.
Find the metal latch on the side of the existing DVD drive, and push it down.
The drive will slide out of the case.
Remove the screws from the old DVD drive, and put them into the same holes on the new drive.
Find the jumpers on the back of the drive.
The jumpers are an array of six small pins, with a plastic piece covering two of them.
Move the plastic piece so that it covers the pins marked "CS" or "Cable Select."
If the DVD drive will be only drive connected on the cable that is connected to the motherboard on the other end, the "MA" or "Master" setting will also work.
Slide the DVD drive into the computer case.
When it reaches the metal latch, it will snap into place.
Connect the two cables (for power and data) that you set aside to the back of the drive.
Close the computer case, reconnect the cables, and turn the computer on.
The new DVD drive will be detected automatically.
http://www.youtube.com/watch?v=cPvm7S0Bc3A
CD-RW DVD DVD-RW Installation and replacement
This might not be your particular computer it might be of some help/guide.
Mar 03, 2014 | Dell Precision Workstation 670 PC Desktop
Dell demension 4600 wont turn on
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Aug 07, 2012 | Dell Dimension 4600 PC Desktop
How to replace the dvd drive on Dell SX280?
Make sure the computer power is turn off. Open the computer, disconnect the two cables from the back of the DVD (one is for power and the other is for data), remove the unit and replace it.
Oct 26, 2010 | Dell OptiPlex SX280 PC Desktop
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
My CD-rom will not work after inserting CD's or DVD will not rev-up what wrong and what should I Do I Have Inspiron 531????
1.The laser optical eye of the CD-ROM drive may be dirty, and needs cleaning.
If the optical eye is dirty, it won't read the information on the disk you install.
A) Computer on, Windows loaded, open the tray of the DVD-ROM drive. (Or DVD burner drive. Whichever drive you are referring to. DVD-R/RW)
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Use a can of compressed air fror computers, and spray air into the DVD-ROM drive.
The optical eye, is located on the bottom of the DVD-ROM drive. (Or burner drive)
The opening in the bottom of the tray, that comes out for your disk, is where you spray the air.
You won't be able to see the optical eye, so how will you know you are spraying the air at the correct place?
If you start at the front of the bottom of the DVD-ROM drive, and work your way towards the back, you will clean the optical eye. Spray across from side to side, and in rows, as you proceed towards the rear.
(Air will make it's way through, and reach the optical eye. The optical eye is not visible, as it can be harmful to the human eye when operating.
Laser.
When the tray is closed the optical eye is exposed. It is not exposed to where it can harm the computer user.
More information that may be helpful, in understanding where the optical eye is located,
http://en.wikipedia.org/wiki/CD-ROM_drive
Scroll down to the heading - CD-ROM drives. Also view the photos down on the right, and the animated GIF.
http://electronics.howstuffworks.com/cd4.htm
How a CD Player Works. Same principle for your DVD-ROM and DVD burner drives )
2.Make Windows reinstall the drivers.
This solution requires physically removing the flat ribbon cable from the back of the DVD-ROM/DVD burner drive, then reattaching it.
Software advice of Updating the drivers, Rollback the drivers, or downloading, and installing the drivers, doesn't always work, or doesn't work.
If the physical solutions I am providing here does not work, we will proceed to the software solutions if you wish. (Comment)
1.Computer off, and unplugged from power. Open the computer case,
Dell Support - Dell Inspiron 531 Desktop PC - Manuals - Documentation - Removing and Installing Parts,
http://support.dell.com/support/edocs/systems/inspd531/en/OM/parts.htm#wp1595069
(Removing the computer cover)
CAUTION!
BEFORE you reach inside you need to relieve your body of Static electricity!
Not trying to freak you out, just needed to catch your attention.
Static electricity, can fry out the delicate computer hardware components, inside your computer.
Touch the metal frame of the computer case.
Computer unplugged from power you are safe.
Touch the metal frame of the computer case, (AFTER you unplug the computer), the computer is safe.
In the above Manual documentation - Removing and Replacing Parts, click on - Drives
Scroll down to the heading - CD or DVD Drive
(Towards the bottom of the page)
Unplug the DATA cable from the CD-ROM drive.
(No.2 in the illustration)
[The two optical drives you have are SATA drives. Dell indicates you have a DVD-ROM drive, (Plays CD's and DVD's), and a DVD burner drive.
(Plays CD's and DVD's, and records)
DVD-R/RW is a 'Burner drive'.
If the information above is correct, you have a SATA power cable, and a SATA Data cable.
(The Data cable transfers information from the optical drive, to the computer, and vice-versa)
The SATA power cable connector, is longer than the Data cable connector.
The power cable connector has 15 pins.
The Data cable connector has 7 pins.
Information,
http://en.wikipedia.org/wiki/SATA
Scroll down to the heading,
Data
Look to the right at the photo. This is a SATA Data cable, and it's connector.
Yours may not be a bent 90 degree elbow, but it will have the L shape in the connector, and 7 pins.
Scroll down to the heading Power Supply. Look down to the right at the photo of the 15 pin SATA power cable connector.
This is Not the cable/connector you want to unplug.
Unplug the SATA Data cable from the optical drive you're referencing to.
Press the Power On button in, and hold it in for a count of Five seconds.
Let go of the Power On button.
Do this two more times.
Plug the SATA Data cable back in.
Close the computer case.
Plug the computer back into power.
WAIT 1 minute.
Turn the computer on. Try the drive.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Wont work
right click on dvd drive on my computer then eject the dvd drive,,,,,,,after that
open bios setting and check device configuration
Jul 02, 2009 | Dell Inspiron 1501 PC Notebook
Dell latitude c510/c610 wont turn on
Ok. Try the below steps.
1) Remove the batter and power adapter. Remove the CD/DVD Drive and any other connected devices like pen drive or mouse.
2) Now hold the power button for 30-40 seconds. Release it.
3) Now connect only the battery and try powering on. If no luck, connect the power adapter and check. (till now do connect the CD Drive - It can be a issue with the drive as well)
4) If no luck, you can try removing the RAM from the laptop and fixing it back.
5) If no luck, contact Dell Support for Replacement of Motherboard.
Apr 16, 2009 | Dell Latitude C510 Notebook
How do I put my new dvd rewritable driver in my dell laptop 1501
All of the below is from your Inspiron 1501 Manual, which if you do not have a copy, you can obtain
a PDF document Here
You will find all below under Adding and Replacing Parts--Optical Drive
Optical Drive
CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in the
ProductInformation Guide.
Turn the computer off.
Turn the computer over and remove the optical-drive locking screw.
Insert a scribe into the notch and push it to the side to release the drive from the bay.
Slide the drive out of the bay.
Apr 10, 2009 | Dell Inspiron 1501 Laptop
Dell (9228C) 200-Watt Power Supply Logo
135 people viewed this question
Alun Cox
