Question about Plantronics DSP-500 Headset
Sound distortion The sound is suddenly terribly distorted. It's not the headset, because it works fine on two other computers. I've also tried it on different USB ports, so I'm assuming the drivers are corrupted. I've downloaded the driver set from the Plantronics website but I can't find the matching files on my computer to replace them. Does anybody know what the driver files are called or where to find them?
I too had this problem. I fixed it by removing a Audio driver from K-lite codec pack. I just uninstalled the whole pack from add remove programs and the headphones work fine now.
Posted on Oct 03, 2007
The headphones don't work on my PC when plugged in to any of the USB ports they are very distorted and are very crackly.
Do you get a good sound from your PC using other headphone? Mean, are you sure you don't have a problem with your PC's audio card?
Jun 27, 2015 | Creative Labs ChatMax HS-720 Headset -...
Sound distortion has developed while listening to a DVD or using Skype
Because I do not know your particular computer in detail, I will answer generically.
Because of the complexity of design where the interaction between software drivers and the hardware are very inter-dependent, it is difficult to determine the fault directly. I would suggest to uninstall the sound card drivers using the device properties manager, re-start the computer, and let it re-install them. If they do not auto install, then do it manually using the respective installation source location.
You can also try downloading the sound drivers directly from the Acer site and re-installing them, or from the respective sound card (chipset) manufacture to see if this fixes the fault.
I am assuming you tried listing to the sound using several headsets or external speakers to test it. I know of cases where a person was complaining about distorted sound from their computer. It turned out to be the speakers were defective and not the computer.
Jerry G.
May 11, 2012 | Acer Aspire 5735 Notebook
Distorted, scratchy sound with Toshiba Satellite
OK, I would restore or recover the computer to manufacturer's original specifications and automatic update to the latest sp3.
Then, I would reinstall your virus protection and see if it's better.
Jul 28, 2010 | Toshiba Satellite A105-S361 Notebook
Distorted sound.
You can try shutting off Audio Hardware Acceleration.
Start > Control Panel > Sounds and Audio Devices > Advanced (Under Speaker Settings) > Performance.
Let us know
Good Luck
Apr 14, 2009 | Audio Players & Recorders
Denon DNS1000 distorted/fuzzy sound
Please visit www.denoindjforums for further help.
Jan 31, 2009 | Denon Dns1000 Table Top CD Player CD...
Rode NT1-A Distortion on "S" sounds and plosives
This is typical component failure. The mic will require professional service. Condenser Microphone Mod Service
Nov 01, 2008 | Rode NT1A Professional Microphone
Audio on Webcam is distorted - seems to be recording at a slower speed and palying back at normal spped
as a workaround you can use the headset, you just need to configure your messenger again to use the sound from the mic input instead from the webcam.
May 28, 2008 | Logitech QuickCam Pro 5000 Webcam
Distorted, horrible sound with IO|2 and guitar
I'm new at it too, but if you increase the buffer to around 256 or higher than you have it anyway, you might get rid of the distortion. Look in the ASIO control panel
Mar 01, 2008 | Alesis iO | 2 Sound Card
Awful High-pitched Noise and Echo Feedback
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Jan 17, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
JVC DVD player plays with distorted sound
Have you tryed a differant audio input on another set or on that same set. Are the audio cables good?? If all this is ok then the D/A converter inside the unit is defective and most likely it wont pay to repai sorry
May 25, 2006 | JVC XV-N40BK DVD Player
Plantronics DSP-500 Headset Logo
361 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
