Question about Tecnik TKL9260 Front Load Washer
Drain hose removal?
I have a frigidaire top loading washer. i am trying to remove the drain hose but am curious how to. it seems that the hose is connected to a rubber section that then attaches to the water pump. But we are unable to detach it. Is the drainage hose supposed to attached in one piece to the water pump/valve or it is two parts (meaning we should be able to detach it from the rubber section). sorry to be confusing.
  • 640 Answers
Remove the clamp and pull hose,,thats 1 peice..onthejob
Posted on Jan 23, 2009
Frigidaire Front Load washer will not drain nor spin? Help! Washer will start and water will enter unit, however clicking occurs and no spin of clothes.
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Mar 12, 2011 | Frigidaire Washing Machines
Water won't drain from the tub, think the hose may be clogged. Is there any way to clean the hose without completely dismantling the machine? It does spin but the water won't completely drain out. We...
Good luck.
Jan 10, 2011 | Frigidaire FWS833A Top Load Washer
Frigidaire top load washer model number FWS6600ES0: during the wash and rinse cycles... whether it's filling or agitating on either... water seems to be draining causing the machine to stop and start...
If it has detected SUDs it may be trying to rid them. Is your drain hose at least 30 inchs above the floor? If is ain't then gravity may be causing the problem. Is the drain hose jammed tightly into the drain? This may cause a siphoning effect.
Oct 29, 2010 | Frigidaire FTF2140ES King Size Front-Load...
My washer won't drain. i need to look for a clog,
The cover at the bottom of the dront should give you access, but first you could try taking the drian hose off the sink and back fludhing you may be lucky to clear it that way.
Apr 17, 2010 | Frigidaire FWS833A Top Load Washer
I need to remove and replace a washer drain hose on a frigidaire combination washer/dryer.
if the conection is not on the back of the washer than you will nead to remove the two screw's at the bottom of the frount panal,remove the panal and you should see the drain line on the left side in the backmake sure you have somthing to catch the water befor you remove the clamp holding drain hose on.
Nov 15, 2009 | Frigidaire FEX831CS Top Load Stacked...
Drain hose seal leak on Kenmore washer
Remove the hose and bend it in circiles see if yo see any cracks in the hose if you do replace it or if it's long enough cut out the bad part and replace it. Alos clamps wear out ver time so try replacing the clamps too.
Jul 17, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Crown Front loader washer, model number CWS3600AS1. The washer is not draining during spin cycle. I suspect the filter, but am not sure how to locate and replace this part.
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Jun 16, 2009 | Frigidaire CWS3600AS Top Load Washer
How do i remove the drain hose ...it seems to be attatched inside the washer
Remove the two screws holding the front panel on (bottom of the front).
You should be able to access the hose connections there.
Good Luck
Quentin
Jun 10, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidair Top loader washer wont drain, but pump is running...
firs get a shop vac and drain the water from the drain hose if you don't have one get a radiator hose clamp from auto zone then remove two bottom screws from washer bottom and pull down on panel you will see a hose coming down from the tub if you didn't have a vac clamp the hose here with the clamp about mid way the pull the hose from the drain pump and check it for jamming there is no filter
Feb 12, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Oct 19, 2008 | Frigidaire GLTR1670A Front Load Washer
Tecnik TKL9260 Front Load Washer Logo
76 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
