Question about IBM ThinkPad T42 Notebook
Ibm thinkpad t42 switch for wireless network
I can not fnd a switch for thewireless network for my ibm thinkpad t42
  • 2 more comments
  • Anonymous Feb 04, 2009
    I HAD THE SAME.
    Go in the bios find the network setting and enable the internal wireless card.
    to turn it on you press thr FN key and f5 together.
    unfortunatly my bios has a supervisor password, do not try to reset the cmos by unplugging the cmos batt. it will want the default password, I cannot pass the poweron password anymore. I will find a way, but now s.o.l.
    Mario in Halifax Canada
  • Anonymous May 21, 2009
    i have the same problem but what is FN key ??
  • hell_child09 May 11, 2010
    the last part was a tough one, how do i configure my wireless adapter?
  • Zmi nazim
    Zmi nazim May 21, 2018
    I have an IBM thinkpad t42, i just rescently had to replace the hard drive. I installed windows xp sp2 and a lot of things wouldnt work. I installed a few drivers and now i can connect to the internet via LAN not wireless. The wireless is not showing up in device manager. It shows a yellow esclamation mark and says "network controller" under "other devices". I try to update and everything but no luck. Not sure whats wrong. Any help?https://www.bluestacks.vip/https://www.textnow.vip/https://www.photomath.vip/
  • IBM Master
  • 32,281 Answers
The T42 has a bulit-in wireless network adapter and a LAN network card. T42s most likely have an Intel wireless card or less likely a Cisco wireless card.
Your wireless network adapter may have been disabled in the BIOS
and/or
The drivers for the wireless network controller has not been installed.
To check the network adapter go to the Control Panel, Click on System, click on Hardware Tab then Device Manager. Then scroll down and click on Network adapters. If you don't see your network controller or you see a yellow ? against Other devices for the Network controller. Then either it has been disabled and/or the driver was not installed.
To get the driver for the network controller you need to dowload it from the IBM/Lenovo WEB site their support/download page from a computer that has Internet access. Make sure you select your laptop model and the driver for your Windows version.
Install the driver and you then need to configure the wireless adapter to suit your wireless router settings before you can access the Internet.
Posted on Jan 23, 2009
    New Friend:
How do I get my wireless network on in my IBM T 42
Posted on Dec 25, 2010
    New Friend:
TURN ON WIFI
Posted on Nov 22, 2010
SOURCE:
Does my thinkpad 42 have a wireless switch? We cant find any networks in range but time warner says my routers good and system properties are good
Hi
IBM ThinkPad T42 is a Series number rather than a Model number.
There are various models in this series. Some models have Wifi capability. Others don't.
Look underneth your notebook to see the full model number, then check here for the exact specifications for your specific model:
http://www.thinkwiki.org/wiki/Category:T42
I hope this helps.
Aug 25, 2011 | IBM ThinkPad T42 Notebook
Connecting to my home wireless
Does it find a signal? do you get an error message? if so what is that message. if it does not find a wireless signal do you have the the wireless turned on most of the IBM thinkpad has a switch on the side of the computer to turn the wireless connection on and off. make sure it is on. please answer the 2 question above for more help
Dec 13, 2007 | IBM ThinkPad T42 Notebook
My wireless card on my T42 ThinkPad doesnt pick up wireless networks. I'm not sure its even installed.
Check Device Manager to see if the wireless card is enabled and working. If it has a yellow ? against it then the wireless card driver was not installed.
Some model ThinkPads have different network cards drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the network drivers and install each driver until you find the right driver.
When you download the drivers, write down the device driver and it’s file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a sub folder on C:\drivers Then install the various drivers from this folder (run the set-up file).
Dec 28, 2009 | IBM ThinkPad T42 Notebook
Where is the wireless switch located on the IBM thinkpad T42
Unlike the newer laptops, the T42 doesn't have it's own wireless switch. So in order to get the wireless working, you need to also make sure that the Power Management driver and the Hotkey driver are installed as well.
Load the drivers in this order:
1) Power Management driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4GXPEG
2) Hotkey driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-68000
3) Wireless Driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70504
After downloading it, you must go into C>Drivers>Win>Wlanint and run the setup file from there.
4) Access Connections (Optional) - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4ZLNJB
Dec 16, 2009 | IBM ThinkPad T42 Notebook
Where is the wireless switch for ibm t42 laptop i have tried fn and f5 nothing works
There will either be a switch on the side of the machine or it will be fn and one of the funtion keys, look for an image like this:
http://hpshopping.speedera.net/www.shopping.hp.com/shopping/images/overview/wireless_black.jpg
Nov 26, 2009 | IBM ThinkPad T42 Notebook
I am trying to connect my sons laptop to the wireless internet that I have .I have refreshed the wireless network connection and it says make sure the wireless switch on your computer is on. where is the...
What is the model of yuor laptop?
There will be wireless switch at the base of the laptop - turn it on. If still nok- - check system tray on the right hand side - you will find wireless switch utility there - enable wireless
Thanx
Sep 14, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Where is the wireless button on t42 thinkpad
There's no hardware switch to activate and deactivate the wireless networking, but pressing Fn and F5 brings up a menu that allows you to turn Bluetooth on/off, WiFi on/off or both. It seems like IBM isn't satisfied with standard toggle buttons like other notebook manufacturers - even pressing the Fn and F7 buttons to switch between internal and external screens, brings up a menu with multiple display settings and resolutions.
Hope this helps,
David
Mar 10, 2009 | IBM ThinkPad T42 Notebook
Not able to connect wireless networks from my T42
What exactly is it doing when trying to connect at home?
Jul 30, 2008 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
34,186 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
