Question about Apex Digital AT2014DV 20 in. TV/DVD Combo
Can this tv get satellite tv
Trying to hook into our satellite tv system. can it be done?
  • 57 Answers
Yes, provided that you have a satellite service provider. I hope this solution is helpful. Please take a moment to rate this solution.
Posted on Feb 11, 2009
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
Surround sound tv
To help you better, you need to provide the make and model of your surround sound system and your satellite TV box..
Nov 28, 2013 | Philips Magnavox MRD500VR System
I am trying to hook by Bose 123 to my Panasonic Vestra 3d tv. I have the cable connected but I am not getting anything
To view a DVD in the Bose system on the TV, connect an HDMI cable (or composite-Yellow, Red, White) to the back of the Bose system (output) and the other end to the input on the back of the TV.
If you have a cable box or satellite and want to get the audio on the Bose system, connect an RCA (white and red) cable to the back of the Bose system (input) and the output on the back of the cable box/TV/satellite.
Switch channels on Bose as needed. Good luck!
Jun 09, 2011 | Bose 3 2 1 GSX System
Can not figure out how to hook the rca system to the tv and satellite receiver,he either gets a picture or sound, can't get both. the user manual we had is very worn and can not be read anymore. can...
The all time best way to hook up the system would be, depending on TV's input output connections, would be hook the satellite receiver directly to TV input, best being HDMI, second being component video(in this case you would use separate audio cable(s), either digital optical, or RCA. Then provide audio out from TV to reciever using digital optical or RCA. You can try to pass video through the reciever however, it is not your best route and you may get a lag between video and audio. Make and model numbers would help in this situation.
Jun 04, 2011 | RCA Audio Players & Recorders
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
I hooked my tv to my direct tv cable box and it keeps displaying no signal. Also, my remote control doesn't work.
Try hooking it to another tv and see if it works then, if not then it's not your tv but your satellite system cable not connected inside or outside, or your dish is not pointed n the right direction
Nov 30, 2010 | Televison & Video
I have no sound while watching tv. It is hooked up to a satellite system and the other tv/satellite systems are working fine. I have sound while I watch a dvd but nothing while watching tv. Its like the...
I suggest you check the satellite receiver first, you can use the component or HDMI cable for the satellite receiver to check it. If still no sound, the TV main board is defective.
May 13, 2010 | Panasonic TH42PX7 42 in. Plasma TV
I can't get the JVC system hooked up with my DirecTV Satellite system where I can use it with my TV and VCR/DVD I tried everything in the manuel please help thank you
You need to plug all the audio "out" of the individual units to the audio "in" on the theater system and change the function/unit switch to the unit you want to listen to. If hooked up this way the theateer system has to be on to get any sound no sound will come from the tv. The easiest way is connect everything to the tv, and if the tv has an audio output jack, plug that into one of the inputs on the theater system. Connected this way anything that comes out of the tv goes into the theater system and you can still get sound from the tv at all times.
May 26, 2009 | JVC TH-G30 Theater System
Lots of components , need proper hook-up
I reccomend a Denon AVR-2809. It had 4 HDMI inputs, all 1.3a and higher, and one HDMI out for your TV!
Jan 07, 2009 | Audio Players & Recorders
Sanyo VCR
get a 2 A/V cords (yellow, white, and red plugs). Plug between the Satellites "video out" jacks and the VCR's "input" jacks. Connect the second cords between the VCR's "video out" jacks and the TV's "video in" jacks. Make sure the VCR is set to the input that you plugged the satellite cords into and make sure the TV is set to the input that you plugged the VCR's cords into.
And then you're done. To record, set satellite to channel desired, set VCR to record on the video input (instead of a channel number) and you're good to go.
Sep 08, 2008 | Sanyo VWM-800 VHS VCR
Apex Digital AT2014DV 20 in. TV/DVD Combo Logo
71 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
