Question about Kenmore Elite 45986 Front Load Washer
Taking bottom panel off kenmore elite front load washer
I need to get bottom panel off to get to the filter drain plug, i cant seem to find screws. any ideas??
  • 640 Answers
Theres three screws at the bottom,,of the bottom panel,,its easier with a torexs head driver,,,onthejob
Posted on Jan 23, 2009
What does the trouble code f2 mean for the kenmore elite 4t washing machine?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 22, 2011 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he 3 front load washer...im getting f error 02. it runs fine until the end of the cycle will not drain or spin.
Kevin
May 22, 2011 | Kenmore Elite 45986 Front Load Washer
I have the kennmore elite he3t. Error code f 02 and it will not drain Is there a solution to this problem you know of?
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Jan 03, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
I have an F 02 error on my Kenmore elite. The
Accessing the Drain Pump on Kenmore Elite and Whirlpool Duet Front Load Washers
  1. Safety first. Unplug the machine.
  2. Put a blanket over the top rear edge of the machine to cushion it and lean it against the wall.
  3. There are three screws located right at the bottom front edge of the machine securing the toe panel. Remove the screws and the toe panel will fall off.
  4. Open the door covering the wiring harness connector and disconnect the wiring harness from the terminals of the pump motor.
  5. Remove the screw securing the pump assembly to the frame of the machine.
  6. Remove the drain hose and tub outlet hose from the drain pump assembly.
  7. Put a small pan or bucket under the pump and turn the large knob counterclockwise to remove and clean the large item filter.
  8. Unscrew the drain pump from the pump housing and check the impeller for any obstruction or damage.
  9. Replace the drain pump if the impeller is damaged or if no obstruction is found in the drain hose, tub outlet hose, and the large item filter.
  10. Install the new drain pump in reverse of the removal steps above.
Jan 24, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load wont spin out code says fo2
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl. rate me nice for the free help!
Dec 10, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Kenmore elite h4 front load washer throwing error code ''f' During middle of cycle i have to push pause and cancle and drain and spin to get it to work
I just fixed this problem in my kenmore washer today. You need to take out the three small screws on the bottom of the front panel. You will need a star shaped screw driver. The panel will fall off when the last screw is removed. After taking off the panel, you will see a large round piece in the middle that should be white; take this piece and turn it to remove the filter. Your filter is most likely clogged with small laundry items or lint and dirt. Remove the blockage and the washer will work great again. This is frustrating, so my wife and I are going out to buy some netting bags for washing small items. Make sure you have a towel under the drain before you open it.
Before doing this though, take a second and reach up under the rubber gasket that circles the inside of the washer door. Your blockage could just be in this area. Our washer had both areas blocked.
Hope this helps
May 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
180 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
