Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Freezer is producing"snow" and freezer burning everything
I have a Whirlpool side by side that is just about 3 years old. Just recently the bottom of my freezer is filled with a solid block of ice and all the shelves, and ice maker are coverd with what my kids call snow. The food in the freezer also tastes frost burned. I have defrosted the freezer, cleared the drain (I think) and it worked good for about 3 days and the problem started again. Can I fix this? Thanks.
  • 2 more comments
  • Anonymous May 11, 2008
  • Anonymous Mar 30, 2009
    same problem trying to make it colder my frisge is pretty much room tempreture
  • Anonymous Mar 24, 2014
    Frost gathering around ice maker and solid ice in bottom of freezer
  • Anonymous Mar 25, 2014
    apparently the freezer drain is clogged. I'm not sure where to find it though
  • Whirlpool Master
  • 909 Answers
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Posted on Jul 20, 2007
Only had bottom freezer refrigerator couple of months, last night looked like it snowed in side freezer, all frosted up
Good day,
If it is under 1 year old, then it is under warranty. Sounds as if the defrost system failed, but you will need to call your selling dealer for a warranty service call. It should cost you nothing.
Aug 07, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
The freezer side of our Whirlpool refrigerator isn't freezing
open the freezer door,do you hear fan blowing if you don't bad evap fan motor,replace it, if that's ok touch the back wall of freezer,remove second from bottom rack and touch back wall,if there is snow or ice there you have a defrost problem,take off the back wall and find out what part is bad,could be t-stat,heater,or timer depending on year,if you can find timer advance it with screw driver and if heater comes on you have bad timer,you'll need a meter to read out t-stat and heater
Nov 01, 2009 | Whirlpool ED5SHAXM Side by Side...
Refrigerator and freezer quit working.
That sounds like it could be the problem. The common causes are a bad defrost heater, defrost timer or a defrost thermostat.
Aug 27, 2009 | Belling BE811 Bottom Freezer Refrigerator
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool conquest fridge; freezer isn't working
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
Oct 03, 2017 | Whirlpool Freezers
Ice forming in freezer refrigerator not getting cold
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Nov 20, 2008 | Whirlpool GS6NBEXR Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
2,647 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
