Question about Turtle Beach Ear Force Tango Call Of Duty Black Ops II Limited Edition Headset
Tango headset not picking up voice and crackling noise
My Paradigm PDR 12 subwoofer has started to make crackling noises. Is this an amplifier malfunction?
Depends when it makes these crackling noises.
If it's when the sub isn't being driven, then it could be the amp. (Check for bulging capacitors on the amp board). If it's when you move cables about then it could be a broken lead or a dry solder joint on one of the inputs.
If the crackling is when the sub is running then it might be the voice coil has distorted due to being overdriven with a poor and highly distorted signal.
Sep 07, 2014 | Audio Players & Recorders
There's a distinct crackling sound on my Headset. What can I do?
I have the same problem, but only in Windows, and only on my laptop (It's a Compaq 515). I do not get the problem if I pair it with my phone, or if I plug the receiver into any of my other computers. The big thing is: If I reboot into Linux, the noise stops.
Feb 08, 2013 | Logitech Wireless Headset H600 Overthehead...
Turtle beach black ops 2, bluetooth not working
im having the same issue with the tango edition ,im holding the bluetooth button down and no turn on but the everything else works ???? any solution
Dec 20, 2012 | Turtle Beach Call of Duty Black Ops II...
My A4tech HS-7P headset is not working?
Hi, I'm having a problem about the headset HS-7P model of A4tech........ my problem is after 30 mins or 1 hour the headset was disable from the control panel of my computer what is the best to do to troubleshot of my headset? Thanks! please answer!
Feb 03, 2012 | A4tech PK Computers & Internet
Microsoft lifechat lx-3000 headset crackle noises
Go to Control Panel>Large Icon View>Sound>Playback Tab>Right Click The Headset Icon>Properties>Advanced Tab>Change the Default format from CD quality to DVD quality and voila. :D
Feb 01, 2012 | Microsoft LifeChatâ„¢ LX-3000 Headset
An external microphone will not cut out the background noises, no matter what settings we change...the built in mic is disabled, but the noise in the background is very loud unless we are talking, and evn...
Most microphones (especially those made for use in a computer) do not remove any background noise. This is usually done via software, but it might not be available on every app out there.
If you can't talk properly using your current mic, your best option might be getting a headset. Headsets have a less sensitive microphone, which will tend to pick up only your voice. If you have a bluetooth headset, you can use it on your computer by adding a bluetooth dongle.
Mar 22, 2011 | Computers & Internet
My Plantronics Gamecom 367 headset has a problem with the mic. For some odd reason the mic will not pick up my voice, or for that matter any sound that is supposed to be detected by it. Instead it gives me...
Sounds like there might be a broken wire (shorting out by touching something else) or something loose in the mic area. This could still be under warranty with Plantronic's. If it is you should be able to have it replaced.
Good luck from Headsets Direct!
Jan 24, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
My mic is picking up all noises around me why fan breathing sounds typing everything....thought it only picked up my voice. It is very distracting Please help Thanks Caroline
All the Plantronics USB computer headsets have noise-canceling microphones. So, if yours is picking up all the noise around you, there is something wrong with your headset. If it's still under warranty, contact Plantronics at 800-544-4660 x5 x5538 for warranty service. If not, it may be time to get a new headset.
Nov 03, 2010 | Plantronics - Usb Multimedia Headset...
Headset earpeice :)
make sure that voice sound is set to come through ur headset and not ur tv speakers.
Jan 01, 2009 | Microsoft Xbox 360 Console
Turtle Beach Ear Force Tango Call Of Duty Black Ops II Limited Edition Headset Logo
Top Turtle Beach Video Game Consoles & Games Experts
James Wishart
Are you a Turtle Beach Video Game Console and Game Expert? Answer questions, earn points and help others
