Question about Tecumseh Engine 5.5hp Horizontal OHV MTD Tapered Shaft for Chippers
How much oil does the 5.5 hp engine take - Tecumseh Engine 5.5hp Horizontal OHV MTD Tapered Shaft for Chippers
I have an older 5 hp. Mtd tiller Do I have to use
Look on top of the machine.If there is an oil fill then no you do not use mixed fuel if yes it needs engine oil,30 wt.If there is no engine oil fill then you use mixed oil and gas,at a 50:1 ratio.
May 30, 2011 | Mtd Garden Tiller (Mtd)
What kind/type engine oil for the 17.5 H.P. Troy-Built Pony garden tractor?
sae 30 weight is used for most garden tractor engines. This is straight 30 weight oil not a multigrade. Most big box stores that carry this kind of gear have it.
Feb 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
WhaT TYPE OF OIL DOES THE 16.5 HP B&S engine take
Your 16.5 hp Briggs engine takes SAE HD30 weight motor oil. I recommend to use a name brand high quality oil. It should take 48 ounces from a complete drain. If you run this engine when it is cold outside (below freezing) then you can change to a 10W30 oil.
Good luck
Sep 16, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
What engine oil is recommended for the Intek 24 hp OHV engine? Will a multi-grade oil work?
multi-grade will be fine it realy dont need a pricy oil in it this kind of engine will run on dirty cooking oil,,with or with out the chips still in it?
Mar 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Intek 25hp came in with less than half a quart, would not start. I drained, replaced oil, cleaned plugs, it started but about the time I turned the choke off 5 seconds of running the engine started making...
does this engine have an oil filter? some of the smaller hp models do not and use a flipper system to throw oil on valves if you have a filter , then your oil pump may have run dry and burnt out
Sep 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Stratton Briggs Stratton Intek V - Twin Engine 21 hp oil had white foam in it
The oil is contaminated with water. Change oil and filter, if it has one.
Jun 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Tecumseh Engine 5.5hp Horizontal OHV MTD Tapered Shaft for Chippers Logo
54 people viewed this question
Top Tecumseh Heavy Machinery Experts
methjd
Bilral
Level 1 Expert
szanghi
Are you a Tecumseh Heavy Machinery Expert? Answer questions, earn points and help others
