Question about SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive
SimpleDrive External Hard Drive
I've just purchased a SimpleDrive External HD (250). It is supposed to be "plug and play" but I have conect it to my pc an to my mac and It does not shows up
  • 1 more comment
  • sblazio Feb 10, 2008
    I have a simpletech external drive_450 gig that my new computer will not recognize !!!
    My old computer ran xp,and the new one vista.
    when I switch on I hear the noise that you get when turning on an external device but vista cannot find drivers please help !!!
    i have silpletech external drive model #96300-40001-01_(other numbers on the back sticker is m051238,and 91000-4079-049,please help !!!!!!
  • Anonymous Dec 22, 2008
    simpletech blinking blue lite
  • Anonymous Mar 12, 2014
    I need a new battery for simpledrive turbo usb 2.0 external hard drive
It you have it formatted as a NTF - it will not write for a MAC but read only. It will work on a PC.
However, if you can format it as a FAT32 system than you should be able to read/write for both a MAC and PC.
Posted on Jan 22, 2008
Not true the simple drive comes as a NTFS which a mac can read if not edit. and He tried it on both a mac and a PC and neither worked. I'm having similar problems to. the device manager say the drive is installed and its drivers are working properly but regardless it fails to show up in the computer section of explorer
Posted on Aug 22, 2007
    Genius:
  • 2,985 Answers
A Purchased Externa HD should be formatted for PC 32bit therefore readable univerally in any PC system but it will not read in a Mac. The would have to be formatted for Mac and will then only read in a Mac. So you decided where you want the drive to go .PC or Mac and we will take it from there
Posted on Jul 10, 2007
  • Anonymous Jul 10, 2007
    Take a look at this
    http://pagead2.googlesyndication.com/pag...
SOURCE:
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
Won't recognize external hd
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
I have a simpletech 250 GB external hard drive model number 96300-40001-001. I was transferring a file from my desktop to the external drive but canceled the operation because I didn't have time to wait....
May seem like a silly question you are not booting up computer with ext drive still plugged in are you?
i am assuming your operating system is on the internal drive.
if so don't have the external plugged in when you start up.
Dec 09, 2017 | SimpleTech SimpleDrive 250 GB External USB...
Lost instruction booklet fo simpletech 250 ex hd
The drive is USB. To access the drive, plug it into a USB port of the computer.
The drive should be recognized by the computer.
I am not sure about Simpletech, however, most drives do not have an "instruction book".
What are you looking for in this documentation?
Dec 14, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
If you click on the apple logo, top left of scree, select force quit and then click eject.
Disconnect the drive and reconnect it. Wait for the drive to show in Disk Utility and select Mount for use in your Mac. Not Dos!
Sep 30, 2017 | SimpleTech SimpleDrive...
SimpleTech SimpleDrive   STI-USB235/160 160 GB Hard Drive Logo
935 people viewed this question
Top SimpleTech Computers & Internet Experts
Ekse
GFXTech
Marvin
Marvin
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
