Question about byD sign d:2232 22 in. HD-Ready LCD Television
My 2322 d:sign tv will p on but screen display blinks and crakling sound it took 1 to 3 mins. to be normal
Every time i on power it takes time before screen display stable it blinks and noise will be heard
Sony Wega Plasma 42XS955. Over 2 wks., gradually
I would check the capicitors on the power supply to see if the they are bulging at the top or leaking. I had a Samsung lcd that starting taking and hour to turn on then eventually it would not turn on. So I checked the power supply and saw four bulging capacitors that I replaced and now it's working like new.
Oct 31, 2013 | Sony Televison & Video
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Sony Bravia KDL-32M3000 Horiziontal bars on picture
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 19, 2017 | Sony Televison & Video
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
NO PICTURE
it is you senser that when you take the back end of your cover off there is a little chip there just tape it lol
Apr 18, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Tv blinks on and off ever 5-10 seconds and display will not turn off
sounds like the sets motor boating from the power supply like a bad regulator IC or a bad capacitor.
Aug 16, 2006 | Sony KV-36FS16 36" TV
byD sign d:2232 22 in. HD-Ready LCD Television Logo
18 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
