My RCA 52'' projection tv has no sound or picture
Hi...our tv barely lasted 2 years, and we had a repairman tell us that it has a bad High Voltage Deflection Circuit is bad....quoted over $600 to repair!!! How muc would it cost to replace this ourselves, and where would we buy it? Thanks!
  • 505 Answers
The board is probably 200-300 dollars. You may be able to get from some distributer like http://www.ued.net/website/index.html
Posted on Jan 23, 2009
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I was watching tv and it made a couple of zapping sounds and the picture went black. I cannot tell if the tv is on or off and when I push the on/off button, nothing happens.
Bad FBT flyback Transfomer or high voltage Trippler block is a common Part that goes Bad
in this Model. Call ACME 1-800-575-9833
You must disconnect FBT lead going to HVT and this will tell you which Part is Bad.
Oct 12, 2010 | RCA P52926 52" Rear Projection Television
I have a 52" RCA TV Model 52w1913yx1, when I turn it on the green LED will flash and then go out. There is no High Voltage and no picture.
I suspect High voltage splitter is bad, can you confirm chassis number?
It is on label on back with model number, something like CTC or PTK 169 OR 171.
IF ONE of these chassis or similar I can tell you how to prove block is bad and where to find and replace--most of these sets also have year they were made on the back.
I am here to help you for free.
SD TECH
Aug 31, 2010 | RCA Televison & Video
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv went off and won't come back on.
the arcing sound is some kind of high voltage leak, which will shut down the tv. pull the speaker grill off and the access board, look at the 3 picture tubes, turn the set on you will see where the leak is, it's usually the high voltage splitter, which has a high voltage wire going into it and 3 high voltage wires coming out going to the picture tubes, if it arcs from the splitter you need to change it, if it arcs from one of the picture tube wires you need to pull the tube out and fix the high voltage leak, and possibly a cooling fluid leak caused it, not an easy reapir, you probably need a repairman.
Sep 08, 2009 | RCA P52926 52" Rear Projection Television
I have a 50 inch rca tv model m50wh185 no picture but has sound
do u hear any high voltage static when you first turn on. possible high voltage problem with the high voltage splitter or focus pack. ussally when there a problem with these high voltage is being generated but not delevered to the tubes
Mar 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv has sound but the picture keeps popping on and off .what can be wrong with it?
2 THINGS THAT USUALLY CAUSE THIS PROBLEM IS
1) THERE IS AN ARC FROM ONE OF THE PICTURE TUBE ANODE LEADS--15.00-- THE TUBES ARE STILL GOOD , JUST THE LEAD IS BAD---NOT EASY TO REPLACE ,,YOU HAVE TO CUT THE OLD ONE OUT AND REPLACE USING SEALANT ....
2) A PART CALLLED A HIGH VOLTAGE BLOCK--75.00--THIS PART TAKES HV FROM A FLYBACK TRANSFORMER ,,,SPLITS THE VOLTAGE TO GO TO THE 3 PICTURE TUBES
KEEP IN MIND ,,IF YOU HEAR A POP--IT'S USUALLY A HIGH VOLTAGE ARCING TO SOME METAL--YOU ARE BETTER NOT PLAYING THE TV
THESE JOBS ARE BEST DONE BY TECH'S -TUNICA
Oct 19, 2008 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA 52 rear projector tv makes chirpping noise wont turn on
You have a bad high voltage transformer. It is the white square device about 3inch square with large red wire coming out. Must be replaced with RCA original NO GENERIC. Also the horizontal output transistor must be checked to see if it is good. Recommend honest qualified tv repairman
Dec 30, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
