Question about Canon PowerShot A640 Digital Camera
LCD not working
Camera only 2 weeks old--my dtr taking pictures on the 4th of July, adjusting vari-angle LCD and the LCD went black and has stayed that way. Camera powers on and takes pictures (look through Viewfinder) but no image on the LCD. HELP?!!
  • 944 Answers
If you need them, you can get all the related user manuals/guides from this link; http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=14109 There are a few possible causes for your problem; Faulty LCD screen - check if you can review pictures on it, even if you can't take pictures using the screen. Bad connection - you can try moving the screen into different positions to see if it comes on at any of them - where the connector goes through the hinge is a possible problem site - more likely the connector has come loose at one end or the other. Software problem - Connect the camera to a PC/Mac, and open the "Zoom Browser EX/Image Browser" program. Find the "Set my Camera" window and you should have "reset to factory settings option" (check the software starter guide page 42) You can reset all the camera settings to their factory default value - this has to be worth trying. I would use the warranty - Canon warranty service is usually pretty good - post back with your general area and we can hopefully find you a service centre. Hope this helps :)
Posted on Jul 09, 2007
SOURCE:
LCD woont turn on properly but the camera takes pictures while the screen remains black or in my case dark grey as its not totally black.
The water has ruined the LCD, water and electronics seldom mix, you are lucky it still will at least take pictures. If it is a high end model then send it back to the Factory repair center listed in the user manual (or phone number to find a repair center).
Jan 13, 2012 | Panasonic DMC-TS2 / DMC-FT2 Digital Camera
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
Last week I was taking pictures outdoors, later on that day my screen went totally black, the green light comes on but the screen continues to stay black, I have changed the batteries
One of three possible problems. First check that you didn't accidentally press the DISP or DISPLAY button. If that's not the problem...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Finally, it could be a loose or poor connection of the screen's flex cables, a very common problem for your model camera. The A620's vari-angle screen is a great option for a camera, but with this moveable screen, the screens data and power cables can and do wiggle loose. It is actually relatively easy to fix by just reseating these cables, but will require opening the back face of the screen of your camera.Please see this other person who had a similar problem with an A630.
May 05, 2010 | Canon PowerShot A620 Digital Camera
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
LCD BLACK
When you say you can view pictures. Do you mean you can view them on the lcd on the camera itself or on your computer? It sounds like the CCD chip went bad most likely. If its not under warranty I would consider purchasing a new camera.
Thank you,
Lee
Jun 24, 2009 | Pentax Optio 50 Digital Camera
Coolpix P90 shows nothing on display and in viewfinder
it might be CCD FAILURE u have to CALL NIKON for FREE REPAIRS just call them and ask them about BAD CCD see link below this problem is active in new cameras as old ones
http://www.imaging-resource.com/badccds.html
Pls rate me WELL !
May 28, 2009 | Nikon COOLPIX P90 Digital Camera
Camera turns on; however,l it will not take a picture. The screen is black except for some varied charachters. I have tried a new battery from Radio Shack with the same problem. Two "camera savvy"...
Hi
are you able to navigate the settings and menus? are you able to view old pictures?
What is the brand and model?
Its most likely a fault in the camera, The brand and model would be helpful I don't see them listed here.
Apr 13, 2009 | Cameras
Camera LCD - black pictures
When I take a picture, there will be know image. Black. I went into the "share" and the image is black. I kept my smart card and the other images are ok but the knew ones are black. Camera has power. I took the smart card off. Still the problem, black. Took the old images off and took some more shots. All black!! MMMMM?
Sep 02, 2008 | Kodak EasyShare DX4330 Digital Camera
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
Dark LCD
Is it possible that you've gone into M (manual) mode and the shutter speed is fast and a small aperture (large number) been selected? Or has the Exposure compensation been adjusted to be -2? Does it do the same thing in fully automatic mode? It certainly sounds like some setting has been adjusted incorrectly.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Canon PowerShot A640 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
