Question about Yamaha RX-V663 Receiver
MCR 840 Blue light Flashing unable to play or extract CD
I have a pair of Auvio colored Bluetooth headphones and i am unable to use them via bluetooth and reseting doesn't work and i cant find the headphones on bluetooth.
The poorly written manual says to hold the Play/Power button for five seconds at which time you will get the blue light, Then hold the Play button again for three seconds to enter the bluetooth pairing mode at which time you will see the alternating red & blue flashing light. Ignore all of that and just hold the Play/Power button for however long it takes to start the red and blue flashing sequence. That means the headset has entered the bluetooth pairing mode. Then make sure whatever device you are trying to pair has its bluetooth pairing mode activated and you will eventually see Auvio BTCHP on your device's pairing window. Select it and you should then be paired.
Apr 29, 2017 | The Audio Players & Recorders
Unable to record from vinyl to cd flashing phono shown then flashing check and no media indicated
Don't see how you can stream directly to CD. The vinyl would need to be extracted as an audio file first, then a burned to CD.
Dec 27, 2012 | HP smc99-012034 - Sc-st Converter Smc...
Dear Sirs/Madam, Please help me the manual of Terapin MCR-TX3300, I need this manual for copy. thanks & regards
Do not know if you still need it. If you still need it, I will send it to you via your email
Jun 23, 2011 | Terapin MCR-TX3300 2-Disc CD Recorder
Motor noise when cd or dvd is playing when volume is low the noice is louder then the music. when you press the unit it stops
Ground potential issue, put a ground cheater on it and unplug all other electronic devices on the circuit.
May 05, 2010 | Yamaha MCR-E150 CD Shelf System
Background light
Set Setting--> screensaver option to blank(by default) and adjust its time
Dec 15, 2008 | Transcend T-Sonic 840 MP3 Player
How to play music cd's
Stop video playback first, then press CD MODE then press PLAY.
Dec 16, 2007 | Pioneer DV-C36 DVD Player
Yamaha RX-V663 Receiver Logo
24 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
