Question about LG WM2016C
Lg wm3431hw noise filter - LG WM2016C
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front door is locked and I cant get my clothes out.
http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp
Check this link, and click on the right side, for the pdf file, to read the manual. Hope this helps.
Mar 29, 2010 | LG WM3431 Front Load Washer / Dryer
Where can i find a free service manual for LG WM3431HW?
Unfortunately you won't find one.
LG only supply their servicing manuals to their repair centres and strictly enforce their copyright, so the manuals are not available to the public and when they do occasionally appear the material has been stolen.
Usually I'd recommend a generic repair manual such as the one by Haynes, but LG's direct drive system and a number of other unique technical features mean that the Haynes book isn't as useful as it could be. The WM3431HW is a large capacity and technically advanced washer dryer so it's certainly not as straightforward to service as a traditional front loading washer or dryer. Many LG spare parts can also be difficult to source outside of their own approved servicing organisation.
I respectfully suggest that you either get LG to fix your machine or post a question on this site describing the problem to see if we can assist you.
Mar 26, 2010 | LG WM3431 Front Load Washer / Dryer
LG WM3431HW is flooding the room
take the lid off
check your inlet valves are they ok
take the back panel off and check all your hoses
find out what is leaking and then i can help you to take apart further
make sure that you unplug it first though.
Feb 12, 2010 | LG WM3431H Washer and Dryer
Need LG WM3431HW-WASHING MACHINE service manual
your service manual should be tapped to the wall behind the toe kick in a manilla envelope
Oct 22, 2009 | LG WM2487H Front Load Washer
LG WASHER/DRYER
Try checking the back, there is a plastic tub that is connected to the drying system and it can get clogged with lint etc. It will also cause the unit to give you longer drying times. It is a poor design. You can also pop off the lid to get a better look but make sure you unplug the unit.
Sgt 48
Jun 09, 2008 | LG WM-2277HW Front Load Washer
LG WM2016C Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
