Question about Xerox DocuPrint C2090 FS Laser Printer
Xerox docuprint C2090 FS fax set up
Need help to set up fax, using same line for eftpos and phone, previous fax worked. Can't seem to receive fax, need to recieve manually as phone switched to answer phone not auto to fax
Thanks, had to get a local IT guy out, not sure what he did but all well now
Posted on Jan 23, 2009
What is error Close C ?
Hi Jim,
I expect it's, "close the cover" referring to the door on the right hand side behind the stacker unit look carefully as it's not always easy to see the problem.
Good Luck.
Aug 17, 2014 | Xerox DocuPrint C2090 FS Laser Printer
FS C2090 Docuprint - how do you remove the toner cartridges.
here are the documents required for you to resolve the issue
please do not forget to vote for me if this resolves the issue
Mar 24, 2010 | Xerox DocuPrint C2090 FS Laser Printer
Xerox Docuprint 3290FS colour multifunction black overtoning badly then spilling during "calibration", leaving very dark background and blotches of toner cyan overtoning mildly during "calibration",...
Xerox does not list that model at all - are you sure the model number is correct ?
It would appear that either the cartridge or fuser may be defective.
Does the machine show any error codes at all ?
Here is a user manual for a similar model 3225 that may help under the troubleshooting section :
This is where you find manuals for all Xerox products :
Oct 28, 2009 | Xerox DocuPrint C3290 Printer
I have a Phaser 8400 printer that needs to be repaired. Where are your authorized service stations in my area (Miami, FL 33142)?
Here you go
DORAL, FL 33172
Phone: 305-882-0435
Fax: 305-882-0436
Products Serviced: Phaser 8200, Phaser 860
Phone: 305-866-1885
Fax: 305-865-8087
Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
depot_logo_small.gif IT SOLUTIONS
7210 NW 58TH ST
MIAMI, FL 33166
Phone: 305-513-0059
Fax: 305-513-0062
Products Serviced: DocuPrint 4508, DocuPrint N2025, DocuPrint N2825, FaxCentre F110, Phaser 3150, Phaser 3400, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 740, Phaser 7400, Phaser 750, Phaser 780, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8550, WorkCentre C2424, WorkCentre PRO 423, WorkCentre PRO 423/428, WorkCentre PRO 428
7240 NW 31 STREET
MIAMI, FL 33122
Phone: 305-471-0093
Fax: 305-471-0113
Products Serviced: Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 840, Phaser 8400, Phaser 8500, Phaser 8550, WorkCentre PE120, WorkCentre PE120I
clear.gif P M E INC
10800 NW 21ST STREET
MIAMI, FL 33172
Phone: 305-994-9222
Fax: 305-994-9922
Products Serviced: CopyCentre C20, DocuColor 2006, DocuPrint 4508, DocuPrint 4512/4512N, DocuPrint N17, DocuPrint N2025, DocuPrint N2125, DocuPrint N24, DocuPrint N24/N32, DocuPrint N2825, DocuPrint N32, DocuPrint N3225, DocuPrint N40, DocuPrint N4025, DocuPrint N4525, DocuPrint P1202, DocuPrint P1210, FaxCentre F110, FaxCentre F116, N2025/N2825, N2125, N3225/N4025, N4525, N4525, Phaser 1235, Phaser 2135, Phaser 3150, Phaser 3200MFP, Phaser 3400, Phaser 3450, Phaser 3500, Phaser 4400, Phaser 4500, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6100, Phaser 6120, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 7300, Phaser 740, Phaser 7400, Phaser 750, Phaser 7700, Phaser 7750, Phaser 7760, Phaser 780, Phaser 790, Phaser 8200, Phaser 840, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8510/8560MFP, Phaser 8550, Phaser 8560, Phaser 8560MFP, Phaser 860, WorkCentre C2424, WorkCentre M20, WorkCentre M20I, WorkCentre PE120, WorkCentre PE120I, WorkCentre PE16, WorkCentre PE220
1523 NW 89TH COURT
MIAMI, FL 33172
Phone: 305-477-2320
Fax: 305-477-3735
Products Serviced: Phaser 4400
Oct 01, 2008 | Xerox Office Equipment & Supplies
Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Jan 08, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Driver for windows vista
If found that if installed the printer as a Xerox DocuPrint 4517 instead of a Xerox DocuPrint N17b then the printer works fine under Vista.
The only thing that lead me to try this was that I found that N17b and 4517 used the same printer cartridges, so I guessed they might be similar under the hood too.
Nov 21, 2007 | Xerox DocuPrint N17 Laser Printer
Receiving fax cut off
There are some settings to check.
1 make sure the ECM mode is ON.
2. Make sure Junk Mail is OFF
3. Be sure Secure receive is OFF.
There is also an adjustment called Distinct ring that may have to be set. it is a slightly differnt set up for differing modles.
Hope this helps.
You may have a bad fax board in the machine. That is the least likely problem. Those boards are pretty reliable, but not perfect.
I must complement you on all the checks you have done. Most people will not suspect the phone line.
Well, one other thing I thought of with the Phone line. If it is a digital phone line, Xerox fax has problems with digital lines.
Those are the things I can think of.
Sep 27, 2007 | Office Equipment & Supplies
Xerox DocuPrint C2090 FS Laser Printer Logo
188 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
