Question about GE WBSR3140DW Top Load Washer
GE topload washer Agitator
How do you remove the agitator from a top load washer? model#wjsr416061ww The machine is out of balance, and the iner tub seems to be to floppy
  • 1 more comment
  • shantam4114 Jan 25, 2009
    Thanks OTJ, I'll try that as soon as I have time...
  • Harold Case Jr.
    Harold Case Jr. May 11, 2010
    it should have a nut or a bolt to take it off from the top, if not check under washer for a nut or bolt. while you are under there check out the balance blocks and stableliser springs, shocks or rods.
  • Anonymous Mar 21, 2014
    remove the agitatoron a ge washer, model # gtwn4250dows
  • 640 Answers
Theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Posted on Jan 23, 2009
How to remove agitator
That is a very old GE model. There may be a screw under the agitator cap which needs to be pried off. Even with the screw removed the agitator usually rusts or bonds to the transmission top. GE had a special pulling tool that was a metal ring that fit over the agitator with 3 set screws in it that you had to screw into the outer plastic of the agitator. A gear puller was then needed to pull the agitator off. Don't know if its worth it considering the age of the machine.
Apr 14, 2016 | GE WBSR3140DW Top Load Washer
Hw to get fabric unstuck from bottom of agitator on a GE Gtwn2800Doww topload washer
Some agitators at the top have a plastic lid that has a bolt under it holding the agitator in washer. Take the bolt out and agitator should come out of washer.
Aug 20, 2013 | Maytag Atlantis MAV6000 Top Load Washer
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Machine does not agitate, will spin and rinse including.
Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Feb 26, 2009 | GE WPRB9220D Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Agitator on washing machine
Hi thanks for your question . Yhe only reason you would want to take the agitator off would be to remove the tub .And thats tye only reason thanks for the question The appliancd doc
Sep 11, 2008 | GE WHRE5260E Top Load Washer
GE WBXR2060V1WW won't agitate...
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from www.partselect.com. PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Jan 12, 2008 | GE WDSR2080D Top Load Washer
Ge washer model wvsr1060a
hi this how it all looks inside http://www.repairclinic.com/0100_24.asp this is half way : http://www.american-appliance.com/service_pages/wp_dd_wash/dddogreplacement.htm this well help you in general http://www.applianceaid.com/direct.html#agitating good luck
Apr 08, 2006 | GE WVSR1060A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
498 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
