Question about GE WHRE5260E Top Load Washer
Washing machine keeps filling with water and won't stop.  We replaced the pressure switch thinking that was the problem but it wasn't.  If we blow into the hose it will stop filling and start agitating.  On the bottom of the hose, it goes into a small box on the side of the the drum.  That box seems to be full of either grease, dirt or a black sock, can't quite tell, how do I get that little box off the side to clean it?  Does it just pull off?  I assume it is sealed on somehow to prevent water leaks.
    Sergeant:
    Champion:
  • 266 Answers
Don't try to take off box. take the are line if you have small compressor. shoot some air through it. it sounds like dirt clogged it. put a gallon of water in the machein if you hear bubbles the line is free. add some bleach to water and run the rinse cycle and it should be fixed.
Posted on Jan 23, 2009
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
My washer won't stop filling with water
either the pressure hose is plugged with debris from the base of the tub up to the pressure switch or the pressure switch in the upper side area or behind the control panel is bad,follow this small hose from the tub base pressure dome up to a round shaped plastic component usually about 3" diameter,this is your pressure switch,when its filling remove this hose off the tub and blow into the end of the hose off the tub,if the switch is good you will hear a click and the water will stop and the machine will start,then you know hose is blocked
May 11, 2012 | Hotpoint Washing Machines
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Water won't stop filling
If the water still flows in when the machine is off the inlet solenoid is faulty, if when you push start it fills and keeps filling then the problem will be with either the electronics or the pressure switch.
You really need to get someone who has experience with whirlpool machines to look at it for you.
Mar 08, 2012 | Whirlpool Washing Machines
I bought a top load washing machine model number WF T7239 UL on 05Nov2010. Water sensor does not seem to work. Water just keeps filling up the drum and starts overflowing once filled.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Nov 06, 2010 | LG Washing Machines
Myn kenmore washing machine keeps filling
You might be wrongly connected the wire just change the wire connection and check it
May 15, 2010 | Washing Machines
Washing machine won't stop filling up
PRESSURE SWITCH
Water inlet valve
Apr 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine will not stop filling with water Simpson Encore 703 washing machine
Does machine stop filling if you discnnect from power? If it does, the problem lies with timer/control unit, or fault in pressure switch/ tube. Check pressure tube (thin rubber pipe that goes from water level selctor switch to side of outer bowl) for holes- replace if faulty. You can test pressure switch by remove pressure tube from outer bowl and blowing thru tube- you should hear the water level switch click when you blow, and then click again when you release pressure.   If it keeps filling even with power off, you have a faulty inlet valve. If you remove top panel (3 screws along top rear-power off first!!), you will see the inlet valves- one for hot, one for cold. The valve is the thing the inlet hoses screw onto. New valves availble from any good spare parts supplier, relatively inexpensive part. Good luck!!
Mar 13, 2010 | Washing Machines
Washer runs but the water does not turn off, THe waterm hot and cold just run until I cut it off manually.
while machine is filling turn of power if the water is still entering machine you have a mechanical fault water valve hot or cold needs replacing if water stops when power turned of you ave an electrical or control problem check water level hose from tub to level switch for damage or perishing if ok check water level switch blow into it see if it clicks if not replace also while blowing hold pressure to see if the diaphragm in the pressure switch is not perished keep me informed
Nov 05, 2009 | Washing Machines
Water won`t stop filling tub
if it's still filling when machine is switched off then water valve needs replacing.if it only overfills when machine is running the pressure pot could be blocked or the hose to the pressure switch could be split or the pressure switch might need replacing
Jun 23, 2009 | Washing Machines
GE WHRE5260E Top Load Washer Logo
102 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
