Mix up some dish washing soap and warm/hot water in a bowl. Use a lint free cloth and dunk it into the water and then wring it out. Wipe the screen down and repeat until clean.
Then use plain water to wipe the screen (on a wringed out cloth) to remove any residue until you have purged and dried the screen.
Tips: Make sure you use a lint free and soft cloth. Make sure you wring out the cloth so that you only have minimal water or soap on it.
DO NOT use alcohol or ammonia based cleaner on the screen.
Expect to spend around 10-15 minutes to properly clean the screen.
We always recommend the professional cleaners found at your electronics store, but you can very carefully clean with a scratch free cloth and a little warm water. The most important thing is to not let it run down into the frame of the screen, it will get in between the layers and can ruin the screens. If you have a screen protector, you can just wipe it clean with minimal water. If you don't you will see and feel the vertical grooves of the lenitcular screen.. if this is the case, you need something to get between the grooves, like a terry cloth or even a clean toothbrush. If warm water doesn't work, step up to mild soap, if no luck there, then try windex but it can destroy some screens with repeated use. Let me know where I can help.
i had a tv repair man come out to see my vizio rp56 tv, n he said it needed a new bulb, and then...
(More)
i had a tv repair man come out to see my vizio rp56 tv, n he said it needed a new bulb, and then later said it might not just b the bulb but something else along with bulb, do u have an idea what else it could be? p.s. he also asked if he could have the bulb as it contained mercury and it could be dangerous for kids.. is this guy just ripping me off?
I have a 55inch sd-p55a3-k-kc.when I turn tv on, the power light turns from red to green for a split...
(More)
I have a 55inch sd-p55a3-k-kc.when I turn tv on, the power light turns from red to green for a split second and then turns back to red. You can hear the tv trying to tun on and then shuts off, kind of like a safety.what do you think the problem is?
i have pdp433-PG display screen i am unable to find right media receiver right media receiver is...
(More)
i have pdp433-PG display screen i am unable to find right media receiver right media receiver is PDP-R03G but does anyone knows any other compatible media receiver with my pioneer pdp433-PG display ? thanks in advance
