Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock light
On the left the control lock light is on and it won't go off. so the machine will not work. how can i get it to work?
  • 1 more comment
  • butrfli373 Jan 23, 2009
    I'm having the same problem. Anyone know how to fix it?
  • kirklands5 Jan 23, 2009
    yes, I have the same problem!! what's going on!
  • Anonymous Jan 24, 2009
    whirlpool washer is stuck on control panel,tried unplugging,and turning back on,but the light wont go off,thereby i cannot wash anything,or can i afford to pay for an answer,help please.
Check your discharge trap. Take off lower front panel under door.Just 3 screws, of course they are torx T-20 size.When the panel is removed right in front is what looks to be a plastic can on it's side with a cap that can screw off. It is a trap that comes from bottom of drum and collects stuff and traps it before getting into discharge pump, anyway mine was full off junk, screws nails small toys. It was packed, After cleaning out and resetting machine it worked again. Worth a try.
Posted on Jan 25, 2009
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
Apr 05, 2013 | Washing Machines
It won't work with the "Control Locked" light on
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
I changed the toner cartridge and now it won't print. The red round light on the control panel is lit. Now what?
If the round red light you describe is a circle of dots that indicates a developer change is due. This needs to be done by a technician but the machine should work fine without doing the developer change.
Nov 10, 2017 | Sharp AL 1631 Copier
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Xl1500 won't type lock light flashes
Try poping off the shift and shift lock key tops to see if the springsb are damaged or sticking down.
DickyO
Aug 01, 2012 | Smith Corona Typewriter XL1500 Refurbished...
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
The locked light stays on but the top load door is not locked, and the washer will not start. I have unplugged the washer but still the cycle will not start.
What is your model type a FAV6800A or FAV9800A?
Are you up to troubleshooting the issue? We would need to see if the Left or Right hand lid lock is signaling the Control Board incorrectly. This could involve using a DVM to measure +12 VDC signaling from the Lid Locks to the Control Board.
A power Cycle of the Control Board won
Feb 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jul 19, 2008 | KitchenAid KHWS02R Front Load Washer
I have a whirlpool front loader washer machine and the control lock light is on and it will not run. the door isnt locked. the deplay light where i tells how many minutes are left in the cycle has dashes
press the button above that light for 3 seconds and the light should go off. control lock is different than door lock. it keeps the kids out from playing with flashing lights!
Apr 23, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
