Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
Danby freezer not freezer
My freezer was set @ 2 to 3, then it stopped working.I turned up the freezer and it worked again for another while , then it crapped out.Wondering if it was my thermostat, and how can i check it out? thanks
  • 828 Answers
If it is the thermostat that is defective the two wires that go to the thermostat for compressor operation can be connected together which would power up the compressor. Unplug the unit before attempting to connect the two wires. after connection is made plug it back in and if the compressor operates and the freezer comes down in temperature you definitely have a bad thermostat.
Posted on Jan 24, 2009
Danby freezer
If it stopped working after being moved, check all the electrical connections. Also check no pipes were broken in the move. Is there any noise from the compressor?
Mar 23, 2014 | Freezers
My refrigerator is warm but the light inside turns on and i have it set to cold, it just stopped working today
Have you unplugged the fridge sir? checked for any electrical disconnections? dust clogging your tubules in the back? Enough space between the wall and fridge in the back? sometimes these will do it. Your fridge needs air to oxygenate the tubules so that it does not overheat and not work.
Jan 07, 2014 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
My danby freezer is defrosting do I set the freezer on zero for colder or 7
7 is the coldest. Defrosting is set up at the factory. It may not be a problem. If it doesn't come out after say 2 hours, then the defrost cycle is faulty.
Feb 04, 2013 | Danby 3.6 cu. ft. / 102 liter Chest...
Danby DUF408WE Upright Freezer not working
Does the compressor feel warm to the touch. If it does, it will be proof that the thermostat is calling for cooling and is probably good. For the obvious questions: Is the freezer in an area below 80 degrees F, is the wall outlet in good shape and not hot to the touch, is the freezer plug not blistered around the prongs, is the door gasket against the face all the way around the mating surface on the chasis. If the compressor is hot, listen for a click every 2 to 5 minutes. If the click is present the starter is your last best hope. The click is the compressor trying to start. Without the proper tools you are pretty much up against a wall. One last suggestion is to check for loose wires under the compressor terminal cover. I would suggest you look up the compressor manufacturer for a visual on cover removal. Dont forget to unplug before attempting compressor cover work. I hope you havent tried to put screws through the outside walls of this freezer or damaged the shelves inside. Both are fatal for the freezer and no repair can be made. Good luck.
Jun 03, 2012 | Danby DUF408WE Upright Freezer
Top part thaws food the bottom half stays frozen. The freezer is 2 yrs old.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 06, 2010 | Danby 16.7 cu. ft. / 473 liter Upright...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
633 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
