Tv keeps getting a no signal and the cable company says its the tv. what could the problem be?
  • connieb0124 Jan 23, 2009
    we have tried all of that and we have 2 other tv's in the house that don't have this problem. anything else you can think of?
  • 505 Answers
Check the wires between the cablebox and the tv, one is probably loose or something. If you have component, check the green one. HDMI, be careful not to wiggle too much an break the cable or jack. If you don't have a cablebox, it could be any cable wire, on the tv, in the wall, even outside. Try different outlets to isolate the problem. Let me know if I can assist more.
Posted on Jan 23, 2009
  • thielectronick
    thielectronick Jan 24, 2009
    If its not external to the tv, then its an internal signal loss, ie needs a new board probably. You have no signal on all inputs?
We can't set up our 32 inch insignia 120Hz tv. It keeps saying "no signal." We have been on the phone to both Insignia and Comcast with each essentially blaming the other. We have a digital cable box...
Tries unplug tv and cable box replug both back about an hours.The tv now,it resetting itself back to the factory setting.The cable box is now resetting and it upgrading it softwares.The tv should work now.Not,tell the cable company sent u another box,still have same problems,the tv board call the Tuner signal board have problems,must be replace.This Tuner signal board,that the board,where the tv incomming broadcasting signal cable plug into it.If the tv is out of warrenty,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 24, 2010 | Insignia NS-L46X10A LCD TV
Anytime i watch a premium channel, on demand movie the image is blurry and jumpy to the point of getting a headache. Regular HDTV seems to be great with the exception of the blacks on occasion, popping to...
It the tv,it have intermittent video problems,with the Tuner board.That the board in the tv,where the cable company broscating signal cable plug into it.U used a HDMI cable to plug into HDMI port hub to get ur HD signal.Take it back talk to Best Buy,tell them this tv have intermittently not supporting HD frequencies changes.Tell them upgrade the tv frameware software for u
.Or keep presisting give u another replacement tv.
Aug 02, 2010 | Insignia 42" LCD Flat-Panel HDTV
I have Dish sattelite and it won't work with memorex under cabinet. They said I need a cable box in between the dish receiver and the tv. Why is this?
You need a receiver for each TV you want to receive the reception on. Your dish receives the broadcast signal from the network and your receiver decodes and recodes the signal to view on your TV. The companies have created their own proprietary equipment to accomplish this to keep anyone and everyone from simply installing their own dish and receiving all of their broadcast channels for FREE. In the olden days when satellite and cable TV was new, that is exactly what people did. Remember those gigantic dishes some people installed in their yards? They would intercept the signals coming from the satellites and hook up directly to their TVs. The companies got smart and started to scramble the signals going up to the satellites to make these home owner dishes obsolete. Because the signals are scrambled, you now need a receiver to un-scramble the signal. I hope this helps and good luck. Please remember to vote d368a18.jpg if you found this helpful. Thanks.
Oct 31, 2009 | Memorex MVUC821 8 in. Under Cabinet TV
NO signal since yesterday in area SY7 0QF on Tv can not get any picture or sound was working before
If there is no signal in the area.
I mean, if the problem is extended to more than one TV set, then call the TV provider company.
If the problem is concerning cable TV (eg. NTL, Virgin), then a local node may be faulty.
If the problem is only on your TV, and the TV has no signal, or static, then check aerial, aerial cables, receiver box and signal booster if present.
If you use cable TV, check wires and receiver box.
If you have Sky TV, then check if you have sat signal, check box and cables.
If you do not find anything wrong call TV company.
If instead your TV stays off with power led on or blinking, then the TV is in fault mode (protect).
Try leaving the TV unplugged from power for one hour. If that does not fix the problem, then call the number listed on the owners manual for support, or ring a local technician.
Sep 04, 2009 | Tvone LM-1501R 15" Flat Panel LCD Monitor
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: http://www.scientificatlanta.com/products/consumers/new_cableboxes.ht64. Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
Guide plus on my rca p52937 tv
You are right, the Guide Plus is transmitted to your tv over the air. If you have a cable company supplying your programs, your Guide Plus will not receive a signal to set up. You will need to get a two-way splitter. It has two connections on one side and one on the other. The side that has one connection goes to your tv. The side that has two connections will connect to your cable supplier and the other to a rabbit ear or outside antenna. Then the tv has to be off over night to restore your Guide Plus.
prs1c-2266633t98.jpg 2-Way Gold-Plated Bidirectional Splitter pixel.gif Model: 15-2587 | Catalog #: 15-2587 pixel.gif
Use this 2-way gold-plated bidirectional splitter to divide a signal to feed two devices, such as TV...
Jan 30, 2009 | RCA P46924 46" Rear Projection Television
Loose cable connection plug
tv back cabinet to second hole to fixing cable hooked
Aug 23, 2008 | RCA F27442 27" TV
Poor cable tv reception.
Problem is direct "ingress" of the terrestrial signal from the TV station (off-air) on to the cable along with the signal from the cable company. Typically caused by faulty/bad/cheap connectors and cables. If you are certain that the signal is clean from the cable company, then the best solution is to replace the cable in your home with good quad shielded cable, with good tight connections made. You could start by checking all "F" connectors top see that they are snug. An amp may increase the signal enough to overcome the ingress and help a bit, but it usually just amplifys the same signal.
Apr 05, 2008 | Sansui DTV2760 27" TV
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
