Question about Dryers
Broken heritage fan speed regulator knobs
I have 3 ceiling fans using heritage 3 speed regulators. the knobs fro all three have broken at different times and I have been unable to get replacement knobs.
Do you have replacement knobs .
The product code is CHW124
App No N14332
  • Dryers Master
  • 19,396 Answers
Buy the replacement from link below:
Ceiling Fan Accessories and Replacement Parts
Posted on Feb 09, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The site provides technical information to assist users resolve their concerns. Unfortunately, FixYa do not supply replacement parts.
An alternative source of replacement knobs would be an electronics/hobbyist store, even Radio Shack. Here is an example. Perhaps it would be to your advantage on "over the counter" rather than online. Bring along the broken knobs for comparison. What would be important is how the knob fits/mates with the protrusion of the switch. Some knobs require a small screw to lock them into position.
Good luck and thank you for using FixYa.
Posted on Feb 08, 2009
  • 679 Answers
Assembling the fan brackets and thermo knob
1) Using the screw, washers, and nuts in the mounting kit bag, attach the large top bracket to the top of the electric fan shroud.
2) Again, using the screws, washers and nuts provided, attach the bottom aluminum bracket to the bottom of the electric fan shroud.
3) Attach the thermostat control knob provided in the electrical kit bag to the thermostat in the fan shroud.
for more elp follow the below link>>
http://www.therangerstation.com/Magazine/Summer2003/ElectricFanInstall.htm
  • Dryers Master
  • 8,220 Answers
Just use black and white together for high and tape off others till you can buy new fans. Switches ain't available.
Posted on Jan 23, 2009
    Genius:
  • 1,269 Answers
Please click the link below where to buy the replacement knobs.
Click HERE
My 3-speed ceiling fan is connected to an on/off wall switch that turns it on and off but the pull chain does not control the speeds. It is stuck on slow speed. I tried replacing the pull chain switch in...
Guess what? A standard dimmer switch will not properly operate a fan motor. In fact, it’s most likely going to damage the fan motor and it could even potentially cause a fire. I’ll admit I even went out and bought a dimmer switch and I sat down to just “make sure” I was doing the right thing when I figured this out.
Standard dimmer switches are designed for the wattage of lights. Fan controls are designed for the amperage of the fan motor. So if you want to control the speed of a ceiling fan make sure you buy a fan speed control that specifically says it works for fans. Fan controls come in quite a few styles. The most common type has been around for quite some time and that is the rotary or dial type. The next most common fan control I found was the toggle that has three pre-set speeds (slow, medium and fast). You can also get a fan control that has a slider control along with a toggle switch.
dimmer+switch.jpgThe type that I want to install is a toggle switch with a small slider switch next to it. I have a feeling I’ll have to order one of these but I’ll check with my electrician tomorrow to find out the scoop. The bottom line is you can’t use a standard dimmer switch to control a ceiling fan. You have to get a fan speed control switch that is specifically designed to operate fan motors.
the short wire leads coming from the switch should be attached to other wires with small wire nuts. Just unscrew the wire nuts, unscrew the finial type cap that holds the switch in place, remove the switch and take it to the store. If your lights are strictly "ON"-"OFF" there should be just two wires from the switch. If your lights are controlled - "One" "TWO" or "THREE" at a time the switch will probably have three wires coming from it.
http://www.ceiling-fans-n-more.com/
Thanks for contacting Fixya.
Jun 14, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
I have one broken blade on the Heritage ceiling fan and would like to know if I can get a replacement blade?
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Accessories-Fan-Blades-Arms/N-5yc1vZbvne
Sep 29, 2014 | Heritage 52" Ceiling Fan
Ceiling fans troubleshooting
Check its speed regulator unit. Gopakumar Gopalan Google
It is faulty. Contact any eletrician.
Mar 02, 2014 | Televison & Video
I have three ceiling fans, whose speeds are regulated by capacitors. What I need is to control all three fans from a single control?
You can buy a 5 amp fan control. If you can find it, a 3 amp would work better. Also, since these fans are low-end, you could even use a 2 amp fan control.
Feb 26, 2014 | Westwind Classic Hugger Polished Brass 52"...
Hi I have three new ceiling fans with a speed controllers (fan power is 220 V 50 Hz 80 , speed regulator 220 V 50 Hz 0.36 Amp,brandNational). And after installation; every thing is working right, the...
Seeing as these fans are 220 volts you probably have to use the control that comes with the fan. What make/model of fan is it? Are you in the USA?
Jul 04, 2013 | Dryers
The motor on my fan seems to be laboring. It won't even start when it is on low speed. Medium speed is slower than it used to be. The fan is about 2 years old. Is there a way to lubricate it or is...
The regulator could be faulty. To check remove the two wires from the regulator and join them. If the fan runs full speed then the regulator is at fault. If not then probably what you think. But fans generally do not need to be lubricated for decades. So, I feel it is the regulator.
Aug 22, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click on...you can turn the knob and increase or decrease the fan speed. You can click on both...
Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
Jun 18, 2010 | Hunter Ceiling Fan Control Switch
Casablanca Delta II fan wobbles terribly at high speed. How can this be fixed?
Use the fan regulator to adjust the speed of the fan, and if it does not adjust the speed, then you have to replace the fan regulator.
Good luck...
May 31, 2010 | Casablanca Fan 3245T Ceiling
Ceiling Fan
the start switch is bad.if you open up the fan you may see a little black looking box thats the switch.if not the switch is on the motor itself.an electric supply warehouse may have the part.
Aug 31, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Dryers Logo
163 people viewed this question
Top Dryers Experts
