Hi, could you please help me? I have sound but no video... Video works to plasma above fireplace if I plug the red/blue/green cables directly into the cable box, but not if it goes through the Denon...
  • Buoyant_Swim Jan 23, 2009
    ... already read the manual. Am wiring r/b/g from cable box to receiver cbl/tv input, than r/b/g to plasma...
    please... help.
    Already called Denon. They do not have customer service help available outside of normal office working hours. I am VERY ready to return this thing!! Horrible support!
    Scholar:
  • 140 Answers
This is typical. Your Denon has "assignable" inputs for both audio and video.
Basics... your AVR is not processing the correct video input of the source selction you have pressed.
I hate to be the pain here but, you are going to have to read the manual related to your Denon model # in order to figure out how to change these settings.
Usually it is not very hard. I suggest going to the Denon website and downloading the manual for your unit. After reading though the manual (usually toilet reading material) you will understand how to change and assign these settings/inputs.
Good Luck...
Posted on Jan 23, 2009
Samsung tv plugging the red white and yellow cables but getting only sound and black and white picture
Hi,red-blu-green is a component signal....but red-white-yellow is a video and audio signal....component and video-audio is a different signal.You can not
Apr 14, 2013 | Samsung Televison & Video
What cable do i need to go from the tele to the amplifier as i have just bought 1 and the above cable is missing please
It depends which type of connections are available on the television you are using and what type of connection the receiver uses.
There are RCA connections (red, white for sound; yellow for video), HDMI is an all in one cable, or a hi def component connection which are blue, green, yellow, red and white.....
Hope this helps.
Mar 24, 2011 | Audio Players & Recorders
Dvd player connected to panasonic viera. picture has blue skin tones and picture isn't centered
I always try the simple things first. check the connection. if hdmi .. then try a differnt cable.
It almost sounds as if one of your connections is plugged in the wrong place.
On component.. red to red, green to green and blue to blue .. then the extra red and white go to the video part .. also may want to check the tv manual - sometimes they share those connections with regular rca connection and easy to plug in wrong place.
Rca connetions - Yellow is video - red and white audio.
S video - one big plug and then red and white audio - make sure the big plug is fully in on both devices - I've seen similar things with s-video plug not fully connected on one end or the other.
Good Luck,
Bill.
Nov 29, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Hi i am trying to work my 'component' on my samsung tv. How do i get this working
Component video input is a high quality analog video signal separated by the three prime colors, red green and blue. You will need component video cables to make this connection.
Turn the television off.
Plug the connectors of each coaxial cable into their corresponding terminals on the TV.
Plug the other end of the cable into your other device that is also using component video, such as a cable box, video game console or DVD player, etc.
Power on the TV.
Press "component" on the remote.
Power on the device.
Nov 07, 2010 | Samsung PS50C451B2D 50 in. Plasma TV
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
I Have just bought this reviever (Yamaha Rx-v365)and im just trying to work out how to best connect all my devises. I have Tivo, Lg DVD player with both yellow, red white cables and blue green red cable...
Hi, firstly some terminology:
yellow cable - video composite (worst quality)
white/red - stereo analog audio
blue/green/red - video component (second best quality after HDMI)
You are correct that RX-V365 doesn't do audio over HDMI. Moreover it also doesn't do any video processing, which means composite video input will go only to composite video output (and not to component); compoment input only to component output and HDMI input only to HDMI output.
If you have more devices of same video output (in your example the component blue/green/red), you can connect them to TV via the receiver. But if only one device of same video output, you can connect it directly to TV. There is no reason to go through your receiver for video.
For audio, you can use either the analog stereo white/red cables (rx365 has 5 such inputs) or better use digital SPDIF connection, which is slightly better quality and more importantly supports 5.1 sound. There are 2 types - coaxial (orange RCA plug, can use basic rca cable) and optical (square black connector). Receiver has 1x coax spdif input and 2x optical spdif inputs. Look at your other equipment to decide which cable to use.
For the analog audio inputs, I think you can assign it either to composite video or component video. So for DVD audio white/red plugs, you can choose if either Video composite yellow plug named DVD will be used, or component blue/green/red named DVD will be used.
Jan 03, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Black Screen
You really need to check your video connections. It sounds like you have the sound cables connected properly, but not the video cables. Are you using the component connection (blue, green, red, white, red) or RCA (yellow, white, red)?? Make sure the color coded ends are plugged into the right places. If you've done this then your display is shot and you'll need to get your warranty paperwork out or call a local repair shop. Good luck!!
Sep 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
I have just purchased a nec px-42vr5g plasma monitor and intend to use it as a tv connected to my sky plus, dvd and wii the guy i bought it from cant find the manual it has lots of sockets etc whats the...
Get the Wii "COMPONENT" cable set. This set has white-red (sound) connectors plus the red-green-blue (component - video) connectors. You can get this cable where they sell the Wii. It will give you the best possible picture with this device.
Plug the Red-Green-Blue connector in their respective sockets on the NEC display (upeer right-hand side). Switch the NEC display to the DTV/HD input (upper right button on the remote).
Please note that this setup does not provide sound since the display does not have speakers.
Use the white-red connectors and plug them into your amplifier or other sound device.
Good luck.
Sep 03, 2008 | NEC Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
