Question about Toshiba SD-K741 DVD Player
Device display now says "bad" and TV display says "Incorrect disc"
Recently we tried to play an exercise disc that we have successfully played several times before; when we insert the DVD it will not play. The player displays shows "bad" and the tv shows "incorrect disc" We have tried 3 other discs all with the same result. Any idea on what the problem could be? I have tried disconnecting/reconnecting the the power with no luck. Thank you for your help. Mike
    Scholar:
  • 150 Answers
Sounds like the player has a dvd mech/picup problem, will probably require a repair that is more expensive than a new player, they are as low as $30 and personally I dont even try to repair my own, I just go buy a new one. There may have been some dirt on the disc that is blocking the laser if you want to try a cleaning disc I doubt it would hurt it anymore.
Posted on Jul 08, 2007
SOURCE:
Will not play dvd's plays cd's
Just like my Samsung unit, it sometimes play, sometime not, Try different dvd, if one plays, leave it playing until finish, try another one and so on. dvd machines need to have some exercise too
Aug 09, 2009 | Zenith DVP615 Portable DVD Player
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
When trying to play DVDs the words unknown disc title appears. Even after several attempts with various DVDs we havent had any success.
have u tried cleaning the hea of ur dvd player?after using a dvd player or cd player for long times of continous play say 6 months or if u play too many scratched discs and u dont clean the head of the player it starts skipping the disc or many a times dosnt recognise the disc so it'll give u errors like "Unknown Disc", "Disk Error" etc so i would really recommend u to clean its head using a dvd head cleaner cd.. its easily available in the video stores or malls.. u can purchase any dvd head cleaner cuz there are number of manufatcures for this. im sure this would solve ur issue.
PLEASE DO RATE ME,WOULD REALLY APPRECIATE IT
THANX
Oct 06, 2008 | Philips Televison & Video
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
DVD won't recognize the disk message below
Try running a DVD cleaner through it and see what happens. You can get one at Walmart for under $10. If that doesn't do the trick then take it to someone that can open it up to clean it.
Nov 26, 2007 | GoVideo VR3845 DVD Recorder/VCR
Cyberhome dvr1600 problems
Try cleannng machine with dvd cleanner if u have staples surplus near u it only costs 10 can cn twice thiswoked for me had a same promblem.
Aug 10, 2007 | Cyberhome DVR 1600 DVD Recorder
Will not play any DVD
I may have bad news for you. Here's my story with the PVD4744S.
I watched over an hour of a DVD-video disc one night, no problems. The next night, I played only the intro; then the DVD player gave a message, "This type of disc cannot be played. Please insert another disc." Thereafter, I couldn't play any of several DVDs.
The manual gives little help:
http://service.us.panasonic.com/OPERMANPDF/PVD4744.PDF
My disappointment is exacerbated by the declining availability of DVD/VHS players with an RF modulator. Maybe Panasonic should create a repair kit for aging devices.
Jun 29, 2007 | Panasonic PVD4744 DVD Player/VCR
No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Jan 29, 2007 | Sony DAV-S400 System
Toshiba SD-K741 DVD Player Logo
940 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
