Question about Behringer XENYX 2442USB Mixer
Can you hook an amp to it - Behringer XENYX 2442USB Mixer
Connect "main out" on the mxier to "input" of the amp with the required cables.
Posted on Mar 17, 2013
Hook up a yamaha htr5840 to a nikko eq-1
generally an equlizer hooks up to the amp auxilary- if the amp has auxilary at the back.then hook up devices to the equalizer.
hook up red and white wires to equalizer output and the other end to amp aux red and white holes at the back of the amp then turn nob on amp to aux.If you dont have aux then try tape function
Dec 07, 2013 | Audio Players & Recorders
How do i hook up the mrp-m1000 to 2 type r subs since it is a one channel amp? the subs r 4 ohms so it should work right?
hook the positive to positive and negative to negative on both subs then run wire to the amp the amp will see a 2ohm load
Jan 07, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
May 19, 2009 | Kenwood KAC-9102D Car Audio Amplifier
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
Behringer XENYX 2442USB Mixer Logo
62 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
