Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsman Compressor runs Intermittantly
I have a craftsman compressor model919.167240 it continualy goes on and off . the switch seems to fine. while looking at it while pressure is building, the switch does not dissengage but the motor will stop. then it will start again. different amounts of time but it constantly does this. Anyone have any ideas?
  • sully646 Jan 23, 2009
    it keeps building I end up using it cause I need it but it builds up. It does not seem to ever get built up to 100 - 120 as I usually end up needing it and am tired of waiting for it. But even when I have waited a while, (as it continues to go on and off) it never seems to get built up all the way
  • David Robinson May 11, 2010
    How much pressure is it building?
    President:
  • Craftsman Master
  • 1,388 Answers
I have repaired many craftsman compessors with the problem that you are having. I just use the process of elimination to find the broken wire. I use a short pigtail and attach it to the motor side of the pressure switch. This will isolate the motor from the switch and the power cord. Use caution not to overfill the compressor as this will test the safety valve. If the motor runs ok then move the pigtail to the powercord side of the switch. This will eliminate the power cord. If problem is within the motor check the connectors under plate and capacitor cover. To test the capacitor you will need to find a meter with cap test capabilities or repair shop will test for free. The cap should test within 95% or printed value in (uf). If all parts test ok then motor could have internal thermal breaker that is weak. Good luck.
Posted on Jan 23, 2009
    Scholar:
  • 140 Answers
Hello again. It would seem that your motor is overheating and the internal breaker in the motor trips and then when it cools down the breaker automatically resets and the motor runs until it overheats again and so on and so on.
One thing that could cause this is your using an extension cord and the compressor motor is not getting adequate voltage which can cause the motor to overheat.
Unfortunately oilless compressors don't last very long and wear out to a point that they can never build up pressure. You can replace the piston and it will work for a while but, I would recommends getting a oil type air compressor and use this one for extra storage capacity. If you need any more help just ask.
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
My Craftsman air compressor has wored fine till now. It does not want to build up pressure beyond 50 psi.yes I did check the drain valve and no leaks. Motor seems to be putting out the rpm's and the oil...
Check for a leak between you compressor head (pump) and your tank. Your pump output may be good but as your tank pressure gets higher the leak will not allow the tank to build up.
Feb 04, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
My craftsman conpressor is a 5 gal type oil free. problem is when I plugged it in to operate it the moment I turn on the switch, it would run a few seconds and tripped my circuit breaker in the house for...
First, the simple answer - check the AMP draw on the compressor. It should be on the motor or compressor nameplate/tag. Even a small compressor can use alot of power, and blow the breaker if there are other things on a circuit.
Does it seem to run OK for as long as it runs?
Oct 26, 2009 | Craftsman Air Tools & Compressors
Sears craftsman 3 gal/1.5 hp air compressor won't run
are you using an extension cord? if so, plug the compressor into a wall socket, if it fires up fine then your extension cord is too long or not heavy enough - other problems could be a bad start capacitor, a loose connection in the pressure switch, or a bad switch
Aug 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman compressor won't cycle off
Hi, First, I think the cutoff pressure is 135psi and there is an overpressure valve so let it run a little longer. I don't know exactly which model you have ( some of these were oil less) but if it is running longer than you remember, be sure to check the oil if necessary, make sure you are not using a long extension as this will cause the motor to slow down and definitely check to make sure the water is drained and the drain petcock is closed all the way. Also check it without an air hose attached. Good Luck!
Feb 14, 2009 | Craftsman Air Tools & Compressors
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Oct 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
339 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
