Question about Frigidaire ATF6000ES Front Load Washer
My front loader showed code err 20 and now water wont come out
All I hear is a humming.
  • Anonymous Mar 24, 2014
    Machine is showing lo code door won't unlock.
    Problem Solver:
  • 5 Answers
Probably has a bad water valve
Posted on Jan 23, 2009
Fault code 75 show err 75 at the end of a cycle .is a front loader wash smart will no longer heat the water.
check the back and see if there are 2 hoses . if so one is hot one is cold. Washing machines do not have heating elements in them
Oct 28, 2016 | Washing Machines
Whirlpool Front Loader Washer Model WFW94HEXR2 hearing a humming sound at the beginning of a cycle and no water enters the machine. Eventually a E01 F03 error code displays. I power off and then wait for...
You have a bad water inlet and it will need to be replaced. Here is the part to order. To gain access to the valve, disconnect the power cord, remove the top plate and you will see the valve.
Aug 31, 2013 | Whirlpool Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
My front loader is reading FH or possibly HF what does this mean?
Water not getting into machine . Check your hoses and screens to make sure they are clean. If you hear a hum but no water enters machine then they are plugged or shut off . If no hum then the fill valve may be bad.
Nov 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We bought a front end loader 06-20-2008, It will run through a wash but want drain the water out, it just hums
take off front cover (2) screws at bottom. drain pump is on lower right corner remove hoses (expect water - I use shop vac) take (2) screws holding pump to washer bottom then take pump apart and remove whatever is stuck in impeller. Check hose for blockage before reinstall.( easy job except you are sitting on floor to do it !)
Sep 24, 2010 | GE WSXH208A Front Load Washer
I have a kenmore 0500 front loader. the on button
You may want to check the screen in the hoses. Unscrew the hoses ( turn off water first) and in the end you will robably find a screen that is clogged. You can pry the screen out and wash it under the faucet or get a new one from the hardware store.
Otherwise the problem is probably with the machine itself.
Jul 19, 2010 | Kenmore Washing Machines
Front Loader Humming
Thats normal just the water valve
Dec 15, 2009 | Samsung WF328AA Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
43 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
