Question about Fellowes P400C-2 Shredder
Fellowes Powershred 220 (1999)
Where can I find a replacement bin for this model? The unit still works great.
    Problem Solver:
  • 3 Answers
Go to fellowes.com and go to contact us or about us and you should be able to find some info and how to get a replacement.
Posted on Jan 23, 2009
Can i purchaser the basket only?
For smaller models like this Fellowes and others typically will not have spare parts as it simply isn't worth the while. However it's worth a call to Fellowes. Their number should be on the unit somewhere.
Apr 17, 2016 | Fellowes Powershred P-48C - Shredder
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
Fellowes Powershred PS80. Took bin out to empty, now wont run.
Had similar problem. Make sure there is absolutely nothing stuck in there. Get the vacuum on it if you have to. It is simply not making proper contact.
Jan 25, 2014 | Fellowes Office Equipment & Supplies
Need part # to replace blades
There are at least 4 versions for this model that take different parts. This model was dis-continued quite awhile ago and i doubt that parts are available anymore. Also, there are 2 cutting cylinders in the machine and they are different lengths. Usually would replace entire cutting head unit instead of just 1 cylinder. But you can call fellowes at 800-955-0959 and see whats still available.
Aug 19, 2013 | Fellowes Powershred C-320C Shredder
I need a parts list for a Fellowes Model C-220 shredder I need full bin sensor part number.
are you certain that the part needs to be replaced. I have seen several of these that could be fixed by bending them (if you hadn't tried it give it a shot) I'll take a look and see if I can find a parts list at work on Mon
Jun 07, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
The bin is full light remains on even though it's empty. How to I get it to work correctly?
Dec 24, 2008 | Fellowes Manufacturing Powershred SB-97CS...
Fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Oct 22, 2008 | Office Equipment & Supplies
Fellowes P400C-2 Shredder Logo
114 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
