Question about Lenovo Computers & Internet
Laptop screen goes blank when charging
When i plug charger into the laptop the screen goes blank - only had machine for a week and hasn't done this so far
Coldcut
  • 1554 Answers
SOURCE: notebook goes blank
your battery may be getting to weak to work.
try booting without the battery.
Posted on Apr 26, 2008
Pyrhyc
  • 2028 Answers
SOURCE: boots up to Safeguard blank blue screen..loggin failed
This generally indicates a hard drive failure. You will need to replace the hard drive and reinstall the operating system.
Posted on Jul 07, 2008
SOURCE: My zune wont properly start up
Suggestion #1.
Suggestion #2.
Suggestion #3.
Try them, 1, 2, 3.
Posted on Mar 08, 2009
ginko
  • 19396 Answers
SOURCE: Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Posted on Apr 10, 2009
  • 83 Answers
SOURCE: Screen goes blank 2 seconds after powering up and then wont work
contact your service provider for a repacement phone if you have warranty or phone insurance. its and internal problem.
Posted on Apr 26, 2009
My laptop quit working. it will not charge or come on at all. please tell me I can do something. I have all my vinyl cutter patterns on it.
Sounds like there was a surge when you plugged in the charger, and it fried the system. Chances are the data is recoverable if you remove the hard drive and install it in a different computer, but to me it sounds like that machine is dead.
Apr 28, 2015 | E-Machines Computers & Internet
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
I have a rapport 337. It won't work with the batteries it tries but screen goes blank. It works fine if it is plugged into the wall. Any help with this would be appreciated. than you
Production of this tester has been discontinued by the manufacturer.
I read a review of this tester, and that person cautioned on the tool's short battery life. He said you need to use high capacity NiMH batteries. He says he's lucky to get an hour of life out of a freshly charged set. Furthermore, the tool does not like to even power up if there is less than a 3/4 charge left of the batteries. He recommended removing the batteries when done using the tool and placing them in a smart charger until needed again. ALL NiMH batteries self discharge even when not in use. You should always have and install freshly charged batteries when you need to use the tool.
If the batteries are old (had many recharge cycles) or were not charged in a smart charger the useful life may have become significantly reduced and in need of replacement.
Mar 05, 2012 | RTO Wonwoo Rapport337 Professional CCTV...
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Screen goes blank on startup.
Are you triply-sure the battery is fully charged and/or the charger is working?
Mar 09, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Notebook goes blank
Apr 26, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
