Question about HP Pavilion zd8000 Notebook
HP Pavilion zd8000 don't startup
Hello, I have "HP zd8000". I press "delete" key during BIOS POST - laptop emergency shutdown (IMMEDIATELY, PER SE) and now don't startup. On laptop - all the LEDs is out-of-work, except AC power light diode, even the power/standby button LED is out-of-work. AC power - ok, battery - ok.
Disassemble, remove the Li-element, for unset CMOS (2 hours), uselessly - Notebook Does Not Startup. Voltage measure rate on MAX1772 (ACOK, 12-pin, have charge of AC power) - OK, either as follows from illumination.
  • ASD809 Jan 23, 2009
    Hi, this ASD?809 once again.
    More detailed...
    When has crash, it was usual rebooting, not in standby mode and during BIOS POST - instead of press "F10", by the rules, I press "delete" key (habitually - desktop).
    Repair.
    To clean CMOS, yeah, I did remove the battery packs. Then i:
    1) Notebook has disassembly.
    2) Removed the real time clock (RTC) battery (several hours).
    3) Has connected all that required for its work.
    3) Replaced the RTC battery.
    4) Connected only AC power to the notebook. Do not reinsert any battery packs at this time.
    5) Turn on the notebook.
    And nothing... Don't startup. All the LEDs is out-of-work, even the power/standby button LED is off, except AC power LED on the front panel, which works.
  • 520 Answers
Remove battery plug in power cable boot up.. nothing may seem to happen but wait a minute or so then press and hold power button down until power light goes out then release button .
try to reboot now.
Posted on Jan 28, 2009
  • 66 Answers
Have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Posted on Jan 23, 2009
  • Casino Dagin
    Casino Dagin Jan 26, 2009
    check the power supply of laptop. maybe it needs a replacement of power supply.
Trying to start up in dvd rom
You need to change boot options in BIOS. Press required F key during boot. Look on the screen since Function keys vary with systems. May be F10? In boot options make optical drive (CD\DVD) 1st. Save and reboot. You should get "Press any key to boot from CD".
Note: Some systems have an ad-hoc boot option during startup. Thus eliminating the need for BIOS change. Might be F12
Oct 12, 2012 | HP Pavilion dv9000z Notebook
Boot hp pavillon zd8000 with usb not possible?
Boot hp pavillon zd8000 with usb is possible.simply plug the USB flash drive with iso and reboot, then press F10 navigeyt Boot Order Mark hard drive, hit enter, Highlight your usb and press F6 so usb was on top of the press F10
May 15, 2012 | HP Pavilion zd8000 Notebook
Hi, i want to set up cd drive on first boot. How do i can access to setup?
If I don't know what computer you have It makes helping you more difficult.
Here are some options for different computers:
  • Turn on the computer, immediately hit the F2 button. - Most computers with Phoenix BIOS.
  • Turn on the computer, during POST hit the Delete button - Most computers with AMI BIOS
  • Turn on the computer, hit Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1 - Older Lenovo.
  • Turn on the computer, immediately hit the F10 button. - Some Dell computers.
  • Turn on the computer, hit Fn+Esc or Fn+F1. Older Dell laptops.
If you tell me exactly what you have, I'll tell you exactly what to do ;)
Jan 28, 2011 | Computers & Internet
Hi, I have a problem whit my "Laptop Notebook HP Compaq Presario CQ61-305SQ ", the fan dosent work , no noise, no cooling, and after about 10 minutes it start to work slower, and when I press "F2"...
The issue is with the fan most probably.Try to perform following steps if nogo the you need to contact Hp tech support for taking the Notebook for repair if its under warranty
1. Restart the Notebook hit F10 key immediately during startup.Once you enter bios settings,hit F9 then Yes-enter key,then F10 --Yes for enter key.
2.During restart hit the F8 key and boot in safemode with networking.Try to connect to internet and download the bios update for your notebook from the link and install it
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-84080-1&lc=en&dlc=de&cc=at&os=4062&product=4033863&sw_lang=
***Imp*** During bios upgrade do not disconnect power cord,battery or shutdown the notebook.It might damage notebook.
After bios update check if fan spinning if no go then contact Hp for repair.
Thankyou
Sep 09, 2010 | Computers & Internet
How to update BIOS on my HP Pavilion zd8000 laptop running on Windows Vista Ultimate
visit HP's site, http://www.hp.com/#Support enter your system details then download bios. after downloading the bios. close all open programs. remove any external device. make sure ac adapter is connected. then run the bios update. that should do it. =)
Jan 07, 2010 | HP Pavilion zd8000 Notebook
How do i remove and install a optical drive on my HP Pavilion zd8000 laptop.
Go to Start->Control Panel->System->Hardware->Device Manager-> select you drive here and delete by pressing del key. Then scan for new hardware. It will show you this drive or any other new drive. Install its drivers and off you go.
Oct 09, 2009 | HP Pavilion zd8000 Notebook
Problems with startup
you have a problem with your memory cards.(simms)
first of swap them around ...this solves 2 probs first to see which if any maybe faulty and to make sure that theyre properly seated.
Dec 21, 2008 | HP Pavilion zd8000 Notebook
Boot up problem
bios default settings
Nov 07, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
790 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
