Question about Yamaha RX-V663 Receiver
Intermittant disruption of Picture and Sound on View TV/HDMI only
Just Bought a Yamaha 663 and hooked up to my Samsung 52 LCD. One HDMI from the TV to the Reciever and one HDMI from the Digital Cable Box to the Reciever.
I am agetting intermittant picture and sound disruption when in this mode. All other inputs seem to work fine until ......I tried hooking up the cable box to the DVD input via HDMI ( which works fine) , but it does the same thing as soon as I enter the cable.
Brought the reciever back , and new one seemed to work for about an hour, but is now doing the same thing.
TVworks fine when I re input the HDMI strait into the cable box , so it can be my connections
Any ideas !
  • 1 more comment
  • Anonymous Feb 02, 2009
    I have the same problem I have exchanged the reciever thinking that the HDMI output was bad. When I put my Blu Ray player cable directly into my TV it works fine, but if I put it into the Yamaha 663, and put the HDMI from the 663 into the TV it does not work.
    Any ideas??
  • jdiraff Feb 08, 2009
    Try uplugging everything for 10 minutes, as I was told
    I fixed it for a while, but had to disconnect the system again.Now I cannot get it to work again
    Did you figure it out ?
  • Anonymous Feb 25, 2009
    i have the same issue and have been trouble shooting for over a month with the seller and we have no solutions. i have my satalite connected to the amp  with a dvi cable with an adaptor to hdmi. i have the out put running through an hdmi. it works fine when i connect the satalite directly through the cable to my tv and when i connect the satalite through a different cable to the amp and still run my out put through the other hdmi. so the problem has to be in the amp.
    Scholar:
  • 144 Answers
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Posted on Apr 17, 2009
  • 28 Answers
Read page 18 of the manual for info on HDMI and compatability with signals...I use cable hdmi to flat screen and just run audio to the 663.. also on the 663 it has to be set along with the flat screen in the set up on the menu's for both components. I have also had to reset the flat screen to auto for correct picture as per toshiba manual.
Posted on May 03, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
Jan 29, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
Panasonic dmr-ez27 I just hooked it up to my 32"
TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs
Dec 02, 2012 | Televison & Video
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Suggestions to hook up HDMI cables
I'd suggest running all HDMI.  I believe your receiver has 2 HDMI in's and one out.  Run the out to your TV and run the components to the inputs on the receiver.  This way the receiver will control the video.  Works good for me!  Hope this helps!
Dec 27, 2008 | Yamaha RX-V663 Receiver
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
Picture cuts out and sound delays
Wow, I have the same problem. I have even tried using never used DVDS, it just freezes after a while. I will get small glitches every few minutes. I am calling Samsung tommorow and raising hell, this was a Christmas present and I am embarrased. I also use HDMI and have changed the set up to 720P.
Dec 01, 2007 | Samsung HT-X40 System
Yamaha RX-V663 Receiver Logo
497 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
