Question about IBM ThinkVision L170 17" LCD Monitor
LCD flat panel monitor blinks logo over and over
IBM Thinkvision 6734-ABO
    Scholar:
  • 140 Answers
Sounds like the LCD monitor is not getting a proper input signal. Check your cables between the computer and monitor. Replace them if need. Also check the pins and make sure that none are bent or disfigured.
Try a replacment monitor from a family member or friend. If their monitor works ok.....then your due for a replacment. The are very little user servicable parts inside.
Posted on Jan 23, 2009
Moniteur thinkvion 6734-ab0
i had the same trouble i changed 2 capacitors on the power supply board a 470uf at 25 volts and a 1000uf capacitor 25 volts.look for any capacitor where the top is bulged and replace them. my monitor works great again.
Jun 22, 2012 | IBM ThinkVision L170 17" LCD Monitor
How can i fix the continous on & off blinking of my ibm l170p monitor
If your monitor is blinking or flickering increase the refresh rate.
Apr 07, 2012 | IBM ThinkVision L170p 17" LCD Monitor
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
Monitor IBM thinkvision 6734-ACO 17", turn OFF
Sounds to me your high voltage powersupply is out. To repair open monitor and remove high voltage powersupply. Inspect the caps on the board. Look for the ends of the caps to be mushroomed out. Replace these caps, usally 470 uf caps. Replace with 25volt caps. Might also be some 100uf caps as well. This is a common problem with all LCD monitors.
Jul 22, 2011 | IBM Computers & Internet
I have an image with the flashlight, but no backlighting on my IBM 6734 lcd monitor
The inverter module is bad or the back light behind the LCD screen has stopped working, I would suggest an estimate if you decide to have it repaired.
Jan 22, 2011 | IBM ThinkVision L170 17" LCD Monitor
IBM Think Vision L170 Monitors. I have a couple with the same issue. Power them on, and the IBM logo flashes for a second, then a blank screen. The indicator LED is green. Powering off/on doesnt...
check for bulging capacitors on the power supply board.if any are bulged their bad.mine was blinking ibm logo i found 2 capacitors bulged i replaced those it works fine.
Sep 27, 2010 | IBM ThinkVision L170 17" LCD Monitor
17 lcd l170 black screen power on but no display
When powered-on, and *NOT* connected to a computer, most ThinkVision LCD monitors will flash, for a few seconds, the IBM ThinkVision "logo", before going into "power-saving" mode. If you don't see that, then it's time to spend about $120, and buy a new 19" (not 17") LCD monitor.
Apr 08, 2010 | IBM ThinkVision L170 17" LCD Monitor
IBM LCD Monitor Model # 6734-ABO
Adam,
Well, to look for a bad capacitors you need to tested with a ESR meter. But if you are lucky sometime you can spotted just by look at the top of a caps for stress mark (like it going to burst out). The caps look like a tiny battery, other look like a blue button with 2 pins. Sometime it not the caps problems...it's beyond repaired. Anyways, good lucks!
Aug 07, 2008 | IBM ThinkVision L170 17" LCD Monitor
Ibm 15" thinkvision lcd monitor
The entire Thinkvision series of monitors have been plagued by capacitors on the power supply board failing.
This sounds worse then it is. For the most part they only fail well after their warranty period, so it's not a design flaw, just old age.
The repair should not cost alot and would be worth a trip to your local computer/TV repair man.
Hope that helps =)
Apr 06, 2008 | IBM ThinkVision L170 17" LCD Monitor
IBM thinkVision
Could be the invertor board is bad and will need replacing.
Jun 16, 2007 | IBM ThinkVision L151 15" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
400 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
