TFT VE710b backlight needs 20 Minutes to light up fully.
I have a 17'' Viewsonic VE710b, a few years old now. When I start the monitor the screen is very dark for about 20 Minutes, then goes back to normal brightness.
It's obviously something with the backlight. I wonder if it's the CCFL or with the inverter. I presume it's related to the operation temperature.
Any hint will is welcome!
  • flameproof May 15, 2009
    I fixed it! Sure it was the inverter. You need to open the case and remove the LCD panel. To open the case you need to pull of the bezel. It's fixed all around the same way, incl. the foot. That will need some modest force.
    The carefully lift out the LCD panel. Open the lock of the two flat cables. Pull out the two cables from the power board.
    Then take out the main board were the 220V come in.
    Then I changed 2 eCaps 470µF/16V, they are located between the 2 coils. It's C903 and C910. If you don't have the same you can try ONE piece if 1000µ/16V (or 25V or more) since the two are parallel.
    Scholar:
  • 140 Answers
The inverter is yoru problem. It takes a while to build up the voltages that is needed to drive the bulbs.
Unless you are operating the monitor in temps below around 40 degrees F... temp is not a factor.
Your prob getting ready to buy a new one. Your inverter(s) are on thier way out.
Posted on Jan 23, 2009
Monitor driver for window 7 64-bit
If Windows Device Manager doesn't deliver try VIEWSONIC.COM. You can find drivers, firmware and manuals there.
Oct 10, 2014 | ViewSonic VE710b 17" Flat Panel LCD...
Re: Problems with Viewsonic VE710b
If it's too dark to see the menu to adjust the brightness, it's a bad backlight - send it back!
Sep 10, 2007 | ViewSonic VE710b 17" Flat Panel LCD...
Tip
I have the overall yellow tint in my lcd monitor there are no magnets close to...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Mar 16, 2008 | Sony SDM-HS73P 17" LCD Monitor
Exactly the same problems.. It's been repaired 2 times and last night it went totally black... Bummer... but the image quality is excellent ( when it works) boooo viewsonic.. Natalie
What parts were replaced, or cheap parts were used? More likely to be either bad caps in the power supply, or bad backlight inverter circuits, see failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VE710b 17" Flat Panel LCD...
Dim monitor
5 years old, lamps are good for about 50 000 to 60 000 hours of life you would have to do the math based on average number of hours per week/month and see where your are, several things to check initially are inside look for blown capacitors, you can find images all over the net Google "blown capacitor image" and you will see what to look for.
Next could be inverter failure as they get old and work pretty hard. Last the ccfl lamps may be dieing of old age like the florescent lamps in buildings, they get burnt at each of the ends and have a hard time lighting up.
let me know what you find.
Apr 20, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
Ctx lcd monitor turns off after 1 second
Your backlight fluorescent bulb is burned out.
Dec 24, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Monitor turns on and off
Is it an HP or a Viewsonic screen ?
Either way, looks like a power supply problem to me, some Viewsonic screens are known to have a problem with their inner power supply card, If your screen is still under warranty I suggest you don't lose time analysing the problem and just make them come and fix/replace it
Nov 06, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
ViewSonic VE710b 17 inch yellowed photograph look
Check and make sure that there is no speaker, power supply or UPS around your monitor.
Mar 16, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Computers & Internet Logo
708 people viewed this question
David Payne
David Payne
