Question about Crosley CDE6000 Electric Dryer
How can I turn off buzzer on Crosley Electric clothes dryer
I cannot find the on/off switch for the Crosley Electric clothes dryer
  • 183 Answers
SOURCE: Crosley Dryer Won't Stop When Door Open
Yes, however befor replacing just check it is not jammed on be abiuld up of fluff around microswitch Regards Advisor
Posted on Aug 30, 2007
TheMobilian
  • 8220 Answers
SOURCE: dryer
Check the blower wheel and filter housing then replace the fuse which mounts on the heater chamber right next to the heatter, the same screw which holds down the heater holds the fuse to the side of the heater.
Posted on Jan 13, 2009
onthejob5130
  • 640 Answers
SOURCE: i have a crosley dryer that tumbles but doesnt get warm at all
check thermal fuse...onthejob
Posted on Feb 03, 2009
  • 91 Answers
SOURCE: Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
Posted on May 27, 2009
  • 56 Answers
unplug unit raise lid by putting putty knife under right and left front edges about an 1 1/2 in on each side. push the knife in to realease the spring clip on each side, look at the heating element in the center back on the right had side of the element case is a small thermal limit that has two white wires coming off of it. to get it out take out the 1/4 in srew that holds the element down, also take off the safety limit switch about the element with the two red wires on it. lift out element slowly you will have to work it out so as not to damage then look inside and see how the limit switch is attached pull out and ohm out or take to service center and buy it should be an LA1053 kit put all back together then try again. you may be able to get it out without removing element also but removal of the element makes it easier.Also take the screw out of the left side and right side that holds the front on about 2 inches down on the inside of panel on each side. look for lint in blower housing on door clean well and clean area where lint screen is housed. i then you should also check your dryer vent it may be plugged up since it blew a thernal limit safety.
Posted on May 29, 2009
Our Crosley CDE6000 electric dryer would shut off midway through a timed cycle w/ clothes not dried. I removed the door and front , then cleaned out a fairly good amount of lint from trap in door. Rep
sounds like your stat (Tod) for short has gone a Tod is what tell the dryer to heat and when to turn off you will have to replace them OK they are right on top of the heater OK hope this have helped
Oct 22, 2012 | Crosley CDE6000 Electric Dryer
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
Crosley cde22bgv, gets warm but won't blow right. Takes about 4 hours to dry a load of clothes.
check make sure the vent is not stopped up and that the blower wheel is not lose
Oct 03, 2010 | Crosley CDE6000 Electric Dryer
MY CROSLEY DRYER DOES NOT GET HOT AND DRY MY CLOTHES.
most likely the element. to lift the top - slide a putty knife between the top and front , push the two clips toward the back and lift the top. the element is at the right rear. check for continuity with an ohm meter
Jan 22, 2010 | Crosley CDE6000 Electric Dryer
My Crosley dryer not drying
You will have to ensure the tub belt is not broken or off the motor pulley. Also, you may have a bad push to start switch or door closed switch. Open door and manual hold in door switch and have someone to push the start button if there is any sound or attempt to start these switchs are most likely good and your problem is with the belt. Hope this helps God Bless
Sep 18, 2009 | Crosley CDE6000 Electric Dryer
Matag performa dryer heats but won't tumble.
After checking the door switch and belt (both ok) I took the wires
from the thermal fuses-- straight wired them together and the dryer started working. I went to my local appliance center,
purchased the thermal fuse kit --replaced the old fuses--now it
runs great.
I hope this helps someone else with this problem.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Dryer runs and tumbles clothes but there is no heat therefore does not dry the clothes
the first thing to check is heating element if it checks good then it will be the thermostat
May 09, 2009 | Crosley CDE6000 Electric Dryer
Electric Dryer, heating el works, exh not blocked, clothes no dry
double check your element temp t-stat and recheck continuity on element. I have known them to work but have shorts in them
Apr 09, 2009 | Crosley CDE6000 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
48 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
