Question about Acer Aspire Computers & Internet
I need Acer aspire 5734Z recovery disc, anyone knows where to get one? Thanks, Doug
I tried Alt+F10 on my laptop. The Acer logo shows up, but the window does not boot up. The screen is blank. Any input is appreciated.
GodSpeed
SOURCE: d2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Posted on Oct 22, 2007
leecom72
  • 4806 Answers
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Posted on Dec 24, 2008
  • 2692 Answers
SOURCE: Acer Aspire 3500 Lost Recovery Discs
Here are all of the downloads for your model laptop. I believe you will find that the disk you need is the last one on the list.
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/au&siteid=8116&areaid=12&formid=3394#results
Posted on Jan 15, 2009
  • 39 Answers
SOURCE: i have 1recovery **** named aspire 5610 dvd2 should i have a dvd1 disk also
go to http://www.sysresccd.org/Download
download the iso and burn it to a cd.
boot your computer with it
read the explanations coming up on the screen and when you see that you can choose how to start, type "wizard"
choose the top choice (auto)
when it starts right click on the desktop and start GPARTED.
one of the discs will be marked as "boot"
right click the disc called "recovery" (or the one that is not marked as boot).
choose manage flags
set it to Boot.
press apply on top (not always needed tho)
in the left picture (the one that opened from the start)
type reboot
remove the cd when you see the acer logo again.
the acer recovery manger should start.
Posted on May 29, 2009
SOURCE: need to reboot acer aspire without recovery disc
My acer laptop does boot up it keeps shutting down after the acer screen what can I do
Posted on Sep 09, 2009
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
Need recovery discs and system drivers
Acer laptops have a hidden partition on the internal hard disk drive which allows restoration of the operating system, applications and drivers to their factory default. Restoration is done by Acer eRecovery Management which can be accessed either through the operating system (if it is still operable) or on powering up by pressing Alt and F10 keys together while the Acer logo is showing.
Feb 12, 2011 | Acer Aspire 5500 5570-2609 Laptop
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
My Friend Has a acer laptop He can not get passed
1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
2. Power the system on.
3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
4. At the eRecovery Management menu it will ask you how to restore.
5. Click on the restore option you would like to use.
Regards.
Jan 15, 2010 | Acer Aspire 3680 Laptop
Alt/F10 Does Not Work Aspire 5315 No Option To Recover
Set the recovery option in the bios to Enabled, exit bios, press ALT + F10 when acer logo appears. Restore will run from the hidden partition on the drive. Let me know how that goes..
Jul 26, 2009 | Acer Aspire 5610-4648 Notebook
Error code 204 - acer recovery disk
need acer Recovery cd? or cannot doing recovery?
when you the ACER logo dring start up press ALT+F10 together recovery is going to start if it doesn have any corrupt file.
May 31, 2009 | Acer Aspire 4930-6862 Laptop
Reformatting Acer 1640
it may be a corrupt recovery disc
if u want to restore to factory default settings simply follow this procedure without inserting recovery disk
When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
everything will be restored to factory default settings
do rate me if it helps ur problem
Jan 28, 2009 | Acer Aspire 1640Z Notebook
Need to restore acer labtop 3680 to original setting
while the acer logo is showing press alt + f10 at same time to enter recovery process, refer to onscreen instructions to perform system recovery
Dec 24, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5920 laptop, cannot invoke Alt-F10 when booting initially
just press alt f10 ONLY when you see acer logo on boot and hold for a sec i had the same problem and its all adout timming hope i help...
my acer a0751h
Feb 14, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
