Question about Franke Strainer Basket Sink Hardware
Can you soften plumbers putty - Franke Strainer Basket Sink Hardware
2 Suggested Answers
  • 760 Answers
SOURCE: Use foam gasket on sink strainer along with plumber's putty?
Usually the gasket is not foam but black rubber. There may have been a piece of foam as packing to protect the stainless. You would apply the plumber's putty directly to the sink. Insert the strainer directly into the putty, compressing the putty. Under the sink, remove the excess putty that extruded through the opening. Apply the rubber gasket to the bottom of the sink, and then the nut (sometimes a "cup" and then the nut) .When the nut is tight, remove excess putty inside the sink. LEAKPROOF!
Posted on Jul 06, 2010
Leaking at jet to tub connection
You can fix that with a small amount of "plumber's putty". You have to remove the jet from the tub first, then smear the plumber's putty around the junction where the two meet each other, then reassemble.
Aug 04, 2014 | Jacuzzi Home
Replacing sink with new swans tone
being a plumber for 50 years I hate the new fittings . I still use plumbers mate = and boss white , with silicone under faucets .
Feb 09, 2014 | Swanstone QZLS-3322 Granite Large/Small...
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
Two rubber gaskets and a fiber gasket came with new strainer. do i use all the gaskets? what about plumbers putty
You are attaching sink strainer to sink opening.
1) Use plumber's putty. Finger-size roll of plumbers putty is applied around opening from top, or applied to the bottom of strainer basket. (Some sinks require silicone. Do not use silicone unless required by the sink manufacturer.)
2) Sink strainer is pushed into the sink opening, making sure it is centered and level.
3) From below, the rubber gasket is applied first, and then the paper gasket is second, and then the basket locknut.
4) Tighten locknut very firmly.
5) Wipe away excess putty on bottom.
6) Push down stainer from top again, and tighten nut some more.
7) Wipe away excess putty around bottom and top.
8) The cardboard washer lets the locknut rotate easily.
Dec 18, 2010 | Moen 22036 Stone Stainless Steel Sink...
Jul 06, 2010 | Franke Strainer Basket Sink Hardware
I have a kohler cast iron enamel sink. The
ALL BASKET STRAINERS ARE PRETTY MUCH THE SAME. PLUMBERS PUTTY WORKS FINE. I BELIEVE ITS THE ORDER OF INSTALL THAT IS CAUSING THE LEAKS. STRAINER AND RUBBER GASKET GOES IN FROM THE TOP. IF NO RUBBER GASKET IS PROVIDED, THEN PLUMBERS PUTTY WILL SUFFICE. UNDERNEATH, ANOTHER RUBBER GASKET AND/OR PAPER GASKET, THEN THREAD ON THE NUT. TIGHTEN IT SNUGLY.
Dec 25, 2009 | Plumbing
I have a new push push drain from mac faucets, and it leaks. I have reversed the rubber gasket that goes under the sink (held on by the brass threaded ring assume that I don't use plumbers putty under the...
The order of installation starting from the top side is the flanged drain then a bead of plumber's putty, and don't skimp on the putty. On the bottom side, first the rubber gasket then the metal washer, finally the locking ring. You must use the plumber's putty between the sink\tub surface and the flange. My mom thought the same thing. She return her drain twice before she asked me why it was leaking:)
Hope this helps.
Sep 11, 2009 | Opella 2-3/8" Push-Push Drain Assembly...
Water leaks from around drain in our korral whirlpool tub. Also from around the light that is in tub. Our local plumbers say they cannot find replacement parts..can it be fixed by just using plumbers...
Use of plumber putty should do the trick. take it apart clean it well and apply the putty. For the light, use silicon glue. You can get a tube at any hardware store. There are many different kinds, just read the label and find one for bathroom use. clean around the light and apply. If your unit is white use white silicone, if it is a color use clear.
Hope this helps.
Aug 27, 2009 | Home
Dripping garbage disposal. looks to be dripping from aroud joint where there may b a gasket?
Your leak is due to a break in the plumbers putty at that location. It will have to be taken apart so the old putty can be removed and new plumbers putty can be put in.
Apr 04, 2009 | Now Evolution In-Sink-Erator ISESEPTICAST...
Franke Strainer Basket Sink Hardware Logo
175 people viewed this question
Top Franke Plumbing Experts
Jim Parker
Jim Parker
richie46
ray gallant
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
