Question about Refrigerators
Defy fridge...tripping the power so I took of the earth wire now it goes on but does not get cold n when I put the earth back on it trips what can that be?
5 Suggested Answers
  • 883 Answers
SOURCE: fridge is tripping fuse box
if this is a new problem that suddenly occurred, then trust the fuse box...the frig has a problem. Most likely a compressor motor that has been electrically damaged...could have been power surges from utility or lightening or unknown. It also could be a wiring problem in the house...mice have been known to chew through wire insulation...they feel the warm wires and are fooled into believing the wire is a live food source and start chewing. A test of this wire problem is to remove the frig and plug in something that will demand close to the same current...(should also contain a motor)...read the frig's label on back of unit.
Posted on Jul 29, 2007
robotek
  • 1512 Answers
SOURCE: suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Posted on Mar 21, 2008
  • 400 Answers
SOURCE: Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Posted on Mar 11, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Aug 29, 2009
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Dec 22, 2012 | Refrigerators
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
My Defy 621 stove causes the earth leakage to trip after a few minutes when the oven is swithed on. The thermostat was resently replaced. Could it be one of the elements, although it seems they are...
Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
Jan 16, 2011 | Ovens
Hello there fridge keeps tripping power every time i switch it on
If random then the compressor has earth leakage when under load. Compressor is faulty. If water flow is disrupted and water filter light comes on for replacement for ice maker/cold water then this can cause an earth leak that will trip the rcd
May 28, 2010 | Max-Fridge STC55926 / STC55927 / STC55928...
The main rcd keeps tripping off round about the same time everyday
do you have a fridge with a defrosting cycle? quite often when a fridge goes into defrosting mode it can dump some voltage to earth which trips the RCD. The other possibility is an electric pump turning on doing the same thing. or it could be a trouble with your power source. if you give me more information i could possibly help you more.
Oct 27, 2009 | Electrical Supplies
Zanussi tc 7102w and when i turn it on it trips power
element short to ground.. coins hair pins clean try again
Aug 17, 2009 | Zanussi TC7102W Electric Dryer
Mar 11, 2009 | Refrigerators
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Defy Side x Side Refrigerator Freezer
Hissing is not good. You could have lost the gas.
Apr 28, 2017 | Refrigerators
Suddenly tripped off house
regards
Graeme
Mar 21, 2008 | Refrigerators
Refrigerators Logo
180 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
