Question about RCA L50000 50" Rear Projection Television
50' rca projection tv
Tv hisses like a litebulb and shuts off then smell it burning
  • 505 Answers
Your high voltage splitter is probably bad, or you high voltage flyback transformer (deflection board). not sure of your model #, is it correct? It may be a lamp but you shouldnt smell burning. You can unplug and let it discharge and find where the burnt up parts are to find your problem. Follow your nose, it always knows!
High-voltage can hurt/kill you.. be very careful
Posted on Jan 23, 2009
My rca 52" rear projection won't stay turned on. It shuts itself off and smells like something burning
Pull back Off and see what is causing burning smell, and CK capacitors on deflection board its the bottom board to the left has FBT flyback transfomer on it 3caps to check are cp150 2200uf 16v use 25v if it is puffed up on top then it is Bad other 2 caps are cp114-cp120 220uf 35v
Nov 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
When I turn on the tv, it makes a sparkly sound and shuts off.
You probably have a high voltage failure causing the TV to sense the overload and shut off. There is about 30,000 volt required to light your picture tube focus the picture. If there is a failure anywhere in this circuit you will get the hissing noise and occasionally an ozone smell. I recommend you contact a TV serviceman to diagnose and repair this problem.
Oct 08, 2009 | RCA D52W23 52" HDTV CRT TV
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
Rca 52'' rear project. d52w20 smells and powers off
you need to replace the flyback number 259296 very common problem and easy repair. You can get a replacement flyback at the following link with free detailed instructions with pictures so you can easially do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Nov 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV shuts off by itself and has a burning smell
mine is doing the same thing but i was able to pinpoint it to a capacitor arching and smoking. haven't replaced it yet so i'm not sure if it's just a bad capacitor or a more involved issue.
Jul 29, 2008 | RCA D52W19 52" Rear Projection Television
Wont turn on smell burning
Can you remove the rear panel and check if the hissing is coming from the flyback? Which is a large transformer with a large red wire coming from the top of it? If so can post a link where you can get a replacement their not exspensive and their easy to replace. If its not coming from the flyback post a picture of where the hissing is coming from and I will identify the parts for you, But I feel its the flyback due to the hissing. respond to this same post so I have your correct model number when you reply.
Jun 25, 2008 | Zenith R57W46 57" Rear Projection...
Replaced convergence fuse tv worked then shut down
Sounds like the convergence power supply is defective. If you need more info let me know
Apr 29, 2008 | RCA HD52W59 HDTV Projection Television
Tv will not power up
Flyback transfromer is bad,part number 259296,part is around 60.00,you might find it at mcm electronics,phone number is 1-800-543-4330
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
Big screen RCA
Bad flyback ? P46921YX1 = part # 239111.................
P46921YX4 = # 250694..............................T.
Sep 18, 2007 | RCA P46921 46" Rear Projection Television
RCA L50000 50" Rear Projection Television Logo
107 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
