Question about Compaq Presario M2000 Notebook
Presario m2000 just shuts down while in use
At an time by its self. Restarts just fine
    President:
  • 1,179 Answers
Usually this problem occurs due to a thermal[overheating] problem. Make sure all vents are free when running the laptop. You can also fix this by upgrading the fan & buying a laptop cooling pad that sits underneath the computer when in use. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 23, 2009
Compaq Presario M2000 stopped turning on
If there is no power going to the laptop then disconnect battery and hold the reset button in for 30 seconds, then try it again. Sometimes the memory can be damaged which can cause the laptop not to boot..?
Feb 08, 2013 | Compaq Presario M2000 Notebook
Repair manual for compaq presario M2000
Free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go down to the Compaq Presario heading. (Sixth line down)
Scroll across, and click on M2000.
This is a PDF file. It may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Suggestion: Save it to your computer. Burn a copy off to CD disk. Run the disk to see if it's good, then delete it off of your computer to save harddrive space)
Plus;
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
http://www.insidemylaptop.com/how-to-remove-inverter-and-replace-lcd-screen-in-compaq-presario-m2000-laptop/
For additional questions post in a Comment.
Regards,
joecoolvette
Oct 14, 2011 | Computers & Internet
My presario m2000 will turn on but comes up with a screen
This is happening because you're not turning the computer off properly, make sure everytime you turn your computer off you go to
Start menu
Shut down.
You need to select start windows normally.
Safe mode will help you with some otherthings
just make sure of turning the pc off properly ;)
Apr 27, 2010 | Compaq Presario M2000 Notebook
Compaq presario m2000 imediately shuts down after
Check for blocked air passages - vacuum out the fan ports. (Don't use canned air - you'll just blow the dust inside, where it will act as an insulator and help things overheat.) Make sure the fans are actually turning. If there's any mold growing inside, that could cause the problem too.And for more contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | Compaq Presario M2000 Notebook
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
Compaq Presario M2000 - Fan not running
It appears your CPU is overheating and is shutting down.
Does the fan spin at all when the laptop is switched on?
The fan could be faulty, if it does not spin freely.
To test the fan, try removing it and connect it to a 12 volt DC power supply, if the fan spins fast then it is OK and the fault is on the laptop, possibly the power supply to the fan. In this case you need professional help.
If the fan appears OK then the problem could be insufficient too old heat sink compound between the CPU and the heatsink. You will need to remove the fan and heatsink and the old compound and put some fresh heatsink compound on the CPU/heatsink and reassemble the fan/heatsink.
Dec 29, 2008 | Compaq Presario M2000 Notebook
Presario M2000 wireless turns off (light and all) randomly
Sounds like a mechanical problem with the button... are you still under warranty?
Nov 03, 2008 | Compaq Presario M2000 Notebook
Fine horizontal lines on the screen
this may be due to fault in your display panel, check it by some hardware professional nearest to you
Oct 03, 2008 | Compaq Presario M2000 Notebook
Presario M2000
i need intel presario m2000
May 08, 2008 | Compaq Presario M2000 Notebook
Desktop Display
Shut down the computer. Turn it on and during the boot process hit on F8 to get into Advanced boot option (if it skips try again after restart the computer), You will see the options. Choose "Last Known Good Configuration" and enter. It will probably will resolve the issue. If issue persist please post for further assistance.
Good Luck
Feb 03, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
