Question about Samsung DV337 Electric Dryer
What is t2 code on samsung dryer DV337AEG/XAA
  • 686 Answers
SOURCE: Can I run the dryer vent vertical and how high?
yes
Posted on Apr 08, 2009
SOURCE: My Samsung electric dryer, model DV337AEG is
You have a bad heating element. I just went through the same problem with mine
Posted on Jul 26, 2009
  • 1531 Answers
SOURCE: Samsung dryer blowing thermostats, constantly
you may need to replace both thermal fuses and or the heating element itself but check to make sure you have the proper temp rating for the thermal fuses
Posted on Sep 27, 2009
  • 1531 Answers
SOURCE: Samsung Dryer Model No. DV337AEG/XAA
not sure of the fault caode never seen it before but i would check he belt and drive motor and make sure there is nothing seized up
rickead1
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
I have a samsung dv337aeg/xaa dryer that does not heat
could be thermistor but also may want to check the heating element, the hi-lo limit thermostat, and see if u are getting full power to the unit as if only getting 120 instead of 240 u have enough to run the motor but not the heater? thermistor located in the housing near the blower, sometimes in the drum or on the door
Jul 27, 2014 | Samsung Dryers
The dryer will not heat. I have no error codes and everything else works fine. I did order a heating element assuming that was the issue but now wonder if I would've had an error code and it could be...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 05, 2010 | Samsung DV337 Electric Dryer
My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
I have a samsung DV337AEG/XAA Electric Dryer which three weeks stopped heating up. We replaced the heating element, along with the thermostat. after that it heated up for 20 minutes then stopped, replaced...
This one isn't going to be easy, you've already replaced the major things. I'm guessing there's a crack in some connector, or other defect, that heats up like the element and opens up- giving the same symptoms. It could be a faulty connection in the power feed to the element connector, or any other connection en route to it. You might see something suspicious. If you have some electronic skills, you might run the dryer until it happens, then quickly disconnect it, and while it's still hot, ohm out all power connections and wiring that could affect the element. You might get lucky and find the open line, being able to hone in on the bad connection, etc. Good luck!
Mar 25, 2010 | Samsung Dryers
Samsung dryer dv317aeg/xaa has code on display
Jun 24, 2009 | Samsung DV317AEG Electric Dryer
Feb 20, 2009 | Samsung DV337 Electric Dryer
Samsung DV337 Electric Dryer Logo
390 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
