Connect usb external hitachi travelstar n155 20gb
Hi, i have a used Hitachi travelstar n155 20gb in a USB 2.0 casing Vipower vp-2528SA2... Haven't used it for a few years and now can't get it up and running. Tried on 3 computers running Xp, Vista and W7. After connecting it says "installing software", seems ok and can remove it, but no drives show up... any ideas? Wim
Crankstart
  • 696 Answers
SOURCE: Hitachi Travelstar HTS541010G9SA00
No the drive is not customized at all. It is a standard SATA Data and Power connector. However, if it was already mounted in a laptop chances are the laptop manufacturer may have put an adapter on the connector end to allow for tight right angle insertion into the laptop chassis which isn't possible with the stock connectors without leaving the drive loose in it's slot.
If this is the case grabbing the connector and pulling straight away from the drive should pop it loose and reveal the stock SATA connectors under it.
If you're having troubles removing this peice, comment back with the make and model# of the laptop it came out of and I'll see if I can pull a diagram for you.
Chris
Posted on Jun 05, 2009
SOURCE: Fantom Drive TFDU16072A Error
2009 06 30 - I just had a similar problem. The Fantom external drive was working fine, but I had to shut down due to a thunderstorm. When I restarted the PC, the drive was not showing up. WHAT I FOUND: First, I didn't find this solution anywhere - everything seemed to point to a new install (or at least how to reformat and start over.) BUT, I right clicked on Computer, Manage, Disk Management - it still didn't show. On the right, under More Actions, I clicked 'rescan disks'. Now it shows up! And all of my data is right there. Whew!
Posted on Jul 01, 2009
Geekinator
  • 183 Answers
SOURCE: A new hard disk drive, Hitachi part
Hello there DLBurkhart.
Here's your geek-steer ...
"...is emitting strange whining sounds every now and then ... Is this strange noise a sign of an impending problem?" == EVERY strange HDD noise is ALWAYS a sign of impending failure.
Peform a "Check Disk" on it ...
chkdsk DRIVE_LETTER /X /R
  • There should be NO surface errors if it's new(er).
  • Regardless, if it's new, then immediately insist upon a replacement.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Posted on Oct 13, 2009
Testimonial: "Straightforward advice, actually reads the problem pays attention to what you say rather than skimming and throwing out half-hearted recommendations."
  • 14 Answers
SOURCE: Hitachi 250GB external hard drive on Mac OSX problem
try to format it in other way like ntfs or fat32....
Posted on Apr 09, 2010
  • 1705 Answers
SOURCE: My XP will not boot when my Hitachi 1TB External
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
Posted on May 03, 2010
Remove drive from Arcdisk 20
If the power plug on the drive doesn't work, putting it into an external case is pointless.
Dec 30, 2013 | Archos ARCDisk 20GB 4200rpm 480Mbps USB...
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I am replacing a Hitachi Travelstar 5K100 HTS541080G9SA00 80GB with a Western Digital 500GB SATA 3Gb/s Hard Drive 8MB 5400RPM 2.5IN Scorpio Blue. A tech told me to use a cloning software to switch the...
You would need to use a "usb" to hard drive cable. It looks like this: http://gizmodo.com/168149/brando-sataeide-to-usb-20-cable
Then, it is simply a matter of "cloning." The other alternative is to find a pc repair shop with a hard drive duplicator. It will copy much faster.
Please rate if you find this helpful.
Sep 20, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
Feb 22, 2010 | Philips Computers & Internet
My drive is fine but my laptop died. I am looking for a compatible laptop that I can plug my drive into to recover the data.
An easier way of doing this is purchasing a 2.5" USB external casing (it's a cheap option too). You can then connect it to another computer via USB and backup your data. From what I can see it's an IDE drive rather than SATA, so make sure you get an IDE compatible casing, if you chose to do this.
Here is a good example of one:
http://www.amazon.com/Drive-Aluminum-External-Enclosure-Capacity/dp/B000FNBYKW
Jan 23, 2010 | Hitachi TravelStar 4K120 HTS421212H9AT00...
Was sent my old internal harddrive after a warranty service to make a backup from and i want to know what connection i need to make it usb. 5K250-250
you can purchase a huge range of drive interfaces from your local computer store. Make sure you get an interface, or USB external case to suit the drive interface ( PATA or SATA ) plug the ting in and connect to your pc through a usb port... then I would copy the entire drive contents onto another drive..
Nov 02, 2009 | Hitachi Travelstar 5K250 HTS542525K9A300...
Drivers
Vista has been known to have multiple USB issues. You can try:
1. remove/uninstall USB instances/drivers in your Device Manager and reinstall but use the USB drivers at the Compaq website for your PC;
2. Update/Patch your Vista US
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Hitachi TravelStar DK23EA Series DK23EA-30...
Computers & Internet Logo
305 people viewed this question
David Payne
David Payne
