Question about Dishwashers
My 14 yr old Magic Chef Model DU4K seems to be leaking (it is dripping into the basement just under where the dishwasher is located). it started when the arm at the bottom of the dishwasher did not seem to be moving so my husband took off the bottom "grill" to see if maybe there was something under there preventing it from spinning. It started to leak when he put it all back together (the bottom arm is still not spinning)
  • mam0408 Jan 23, 2009
    we went to the Magic Chef website and looked at all the parts and how they are put together. From this he determined that he had put the strainer grill on the wrong way and that is what caused the leaking. As to the arm not turning we also got the answer from their website. It seems that the seal had dislodged so it was stopping the arm from spinning. He repositioned the seal, put everything back on (the correct way this time) and the arm is spinning, and there is no more leaking.
    Scholar:
  • 93 Answers
Being 14 years old I dought if spares are still available for this machine personally at 14 I would rather replace the unit if you are not in a possition to replace it you could advise from your local appliance repairs as to weather parts are available and what the cost is of parts for the unit before you decide to possible throw good money after bad (spend money on something that has very possibly seen the end of its life)sorry for the bleek outlook but reality is that old machines such as this seldom are worth repairing.
Posted on Jan 23, 2009
Magic Chef dishwasher leaking from the shaft hole attached to the drain solenoid, how do I get the shaft out to replace the seal that is bad and causing the leak?
on that shaft is a C clip on the inside of the pump asm. remove that clip and the shaft will come out,in the pump housing between that drain flapper and the solonoin is a seal i would give you the part number for that seal but the model number listed in your question uses a seperate drain pump and doesnt have that flapper/soloniod so please send correct model number and i'll get ya the seal part number.
Aug 17, 2011 | Magic Chef CDB1500AWS Built-in Dishwasher
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
Magic Chef oven does not work but all burners do
25 yr old oven...........so I bought a new one with a few blemishes for $200.
Apr 04, 2010 | Magic Chef Ovens
PUMP WILL NOT STOP WHEN YOU PUT POWER ON . PUMP STARTS AS SOON AS YOU PUT THE POWER ON TO PICK A WASH PROGRAM EVEN BEFORE THE DOOR HAS BEEN CLOSED.
I have seen this on my unit. There was water in the drip pan under the dishwasher. Water in the drip pan comes from a leak. In my case, the water valve was getting so old that it was letting too much water into the unit when it was trying to fill. This cause the filling station to over flow into the drip pan.
A quick fix - I removed the water from the drip pan under the unit and I was able to turn down on the supply valve in the basement to limit how much water could come in. This allowed the unit to run without overflowing. I will replace the water valve soon.
Other possibilities, the float device used to detect too much water in the drip pan or too much water in the unit is stuck in the too full position. Or the pump out pump is stuck and not moving water.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Magic Chef DISHWASHER - mODEL du4k, STOPPED DURING drain cycle
I am assuming that the pump motor is bad, and since the unit is at least 15 years old (just guessing), we decided to wash the dishes by hand till after the holidays!!
Merry Christmas
Dec 09, 2009 | Magic Chef Dishwashers
The spring mechinism which automatically closes the door on my under counter Magic Chef dishwasher has failed. How to fix it?
call your nearest appliance parts store with you model and serial # and ask them to look up the door handle/latch mechanism assembly and replace it.
Oct 11, 2009 | Magic Chef Dishwashers
Why does my magic chef refrigerator leak water on the floor
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Jun 30, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
LAST NIGHT OUR LESS THAN 1 YR OLD MAGIC CHEF MICROWAVE TURNED ON BY ITSELF AND WE TRIED EVERYTHING TO GET IT TO CANCEL INCLUDING UNPLUGGING IT SEVERAL TIMES. IT HAS A MIND OF ITS OWN NOW. MODEL #MC0160UB...
Have you looked on the magic chef recall website? I read about the same problem on the Samsung recall website about microwaves turning themselves on.
Apr 01, 2008 | Microwave Ovens
Dishwashers Logo
136 people viewed this question
Top Dishwashers Experts
