Question about Philips MCM309R Shelf System
How to switch off Sub Woofer in philips mcm309r? It's good for rock, but I don't need it for listening classical music. Can't find any button or setting how to switch off it
    New Friend:
I have the same system, mcm309r and unfortunately, the power is routed thru the subwoofer meaning the subwoofer has the power cord and the stereo plugs into it, so if you unplug the sub-woofer, you unplug the stereo.
Posted on Jun 19, 2013
  • 8,596 Answers
Unplug subwoofer cable from main unit
Posted on Apr 08, 2008
SOURCE:
WHAT SIZE AND TYPE BOX DO I USE FOR ONE PIONEER TS-W304C SUBWOOFER
You have a lot of choices for this. First, unless you are tuning the sub to a specific frequency you have options. You didn't specify the size of sub so it's difficult to say specifically, but if it's a 12 inch sub, you need about 1.5 to 2 cubic feet. Of course the performance of the sub depends on the music you listen to. If you listen to rock, pop, classical, or country, I recommend a sealed box. A sealed box gives you better control over your sub. The air acts as a cusion and decreases the return time of the cone to rest position. This gives you tighter bass. If you listen to rap or hip hop, I recommend a ported enclosure. This type of enclosure allows for more cone excursion, thus allowing the sub to recreate lower frequencies. Hope this helps.
Aug 12, 2011 | Pioneer TS-W304C Car Subwoofer
My yamaha rx-v565 wont turn my sub woofer on.It detects that it is there during setup but doesnt turn it on during music or movies.
make sure the switch on your sub is on, and also if there are no "sub signals" then it wont kick on tru listening/watching somthing with alot more bass to see if it kicks on
Dec 17, 2009 | Yamaha Rx-v565 Receiver
Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
My mom just bought this philips sound system and the subwoofer is not producing any sound. The other speakers work just fine but the sub woofer does not work. I was wondering if their was any call backs or...
Press the surround button on the Philips remote to see if the subwoofer will begin producing noise - the surround button switches the mode from simple stereo to full surround. I would test the surround button while watching a DVD, because not every tv channel is going to even produce surround effects. Good luck!
-Tha Mp3 Doctor
Dec 18, 2008 | Philips HTS3450 System
I cant have my own mp3 songs for my ringtone on my LG Chocolate. it keeps playing the Ring 1 ringtone.
You can: MP3 Player * Download and listen to music with the built-in MP3 player.
* Don’t settle for boring polyphonic ringtones, select an MP3 as your ringtone. (Also supports AAC, AAC+, AAC++ and WMA formats)
* External MP3 button for easy access to your music.
* Graphic equalizer with 6 sound effects to choose from (General, Classic, Jazz, Pop, Rock and Bass).
You should try to find a music or download some mp3 music and when playing click on set as ringtone.
Jul 28, 2008 | LG Cell Phones
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Subwoofers and amps
If you replace the head unit, that will make a big difference. If not, then it really depends on the type of music you primarily listen to. From a single sub setup, an 8 or 10 in a sealed box is best for punchy base, i.e. alternative, hard rock... A 12, 15, or 18 is designed to reach those lower bass frequencies and are suited better for ported enclosures. I.e. Rap, bass heavy Regge, etc...However, that's not to say that you can't go back and forth between them. The main difference is that a 10 and below tends to be more accurate, and can follow the kick drums, for example, a lot faster than larger woofers. Determine what your primary listening music is, what you want out of your system, and a maximum price for everything first. Then, I can suggest woofers, amps, etc.
Jun 24, 2008 | Car Audio & Video
Philips MCM309R Shelf System Logo
215 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
